Question about JVC MX-D602T Shelf System
It keeps blowing the 4A-125V fuse every time I plug it in...
  • 30 Answers
There is something shorted in the system. often it is the audio output which fails especially if it is run at high volume levels. Unless you are trained in electronics, I suggest you find a repair shop that repairs audio equipment. (Sorry) Hope this helps
Posted on Jan 03, 2011
Put new 125V 4A fuse in and it keeps blowing it out.
Something on the powre supply board has shorted out.
Repair the board or buy a new one.
Dec 03, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
Keeps blowing the 4a 125v fuse inside when I turn the power on
then there is a fault with the power supply in the tv
Mar 27, 2011 | Sanyo Televison & Video
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
4a/125v fuse blows every time I plug the TV in.
the smps needs repair.the primary circuit is shorted.stop the game with the fuses and contact the service! dont mess with the board of the smps. the voltage there is at least 200v dc and the current is strong enough to kill somebody!
May 04, 2010 | Sylvania LC320SL8 Television
The fuse is blown in the charger. I want to replace it. 4A 125V
Usually when the fuse blows in the charger there is some other malfunction there in the board. The charger for your tool is listed as obsolete to contact the service center, and in doing so ask them for the proper fuse, or replacement charger.
Oct 05, 2009 | Dewalt DC727VA Heavy Duty 3/8 Inch 12 Volt...
Sylvania edtv ld200sl8
will not power. the fuse 4a 125v blows immediately when plugged in.
Sep 04, 2008 | Sylvania Televison & Video
Sanyo tv blows fuse when you turn it on
u have a short in the power supply section
Oct 24, 2007 | RCA F27242GY 27" TV
The tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Aug 14, 2007 | Sylvania 6432GG 32" TV
JVC MX-D602T Shelf System Logo
61 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
