Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Hi i have installed my router over a year ago now but am wondering how i set up security as others in my area can pick up my network easily without any passwords and it is slowing my computer down thanks.
  • 84 Answers
In general, you can follow the basic steps below.
I would recomend using WPA2 or WPA secutity over WEP. (as this is a stronger type of wireless security)
- Open a web browser on the computer.
- In the address bar of the web browser, type http://192.168.2.1 (default router ip address, you may have changed this)
- Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit. (if you have already set up a password to login to the router then enter it here)
- Click on Security in the left-hand column under the Wireless heading.
- Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
- Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
- Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
*NOTE* Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
= Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
If you need assistance with how to re-configure your computers, then please provide the version of windows that you are using.
Basic steps are:
-Disable the current Wireless Connection
-Enable the Wireless Connection
-Search for available wireless networks (look for your SSID wireless network name)
-you will be prompted to enter in your PSK and then save your settings
Posted on Jan 03, 2011
Hp netbook not picking up wireless network?
Are you sure your hubby is picking up the wireless from his phone or is he just getting a signal from a cell phone tower?
The reason I ask is that once you hit the button to set the router back to the factory default, the wireless on the router is turned off.
You have to go into the router and enable the wireless and give it a SSID (unless you want the Dlink default) and you have to give it a password if you want it secured.
Jun 10, 2012 | Computers & Internet
I have wireless belkin 54 g how to setting security password cause all people can use my wireless thanks
Hi robidublin20,
If you want set a Security Code or Network Key to your network so that other people can't connect to your router you need to access your router.To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can set the security type of your router to WPA or WEP to make it secure. Under that you can set the Security Code or Network Key. Personalize it so that that you can easily remember it.
Don't forget to say thanks. Thanks for using Fixya.
Feb 07, 2011 | Belkin F5D7234-4 Router
Cant connect to internet on ps3
Welcome to Fixya.
If you want to connect your PS3 to the internet you need to know the configuration or settings of your router.
To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is blank. Go to the Wireless Settings you'll find your SSID or Network Name under Wireless Network Settings and under Security Mode you'll find the Network Key or Passphrase. You can alsoThen Personalize you Network Key or Passphraseso that you can easily remember it. Take note of the SSID and the Network Key and the Security Mode (WEP,WPA or WPA2).
Steps on Connecting PS3
1. Power-cycle ALL network equipment. Turn off (unplug) ALL of your network equipment, including any Wireless Access Points, Routers, Voice Over IP (VOIP) Modems, and Broadband Modems for two (2) full minutes.
2. Confirm that your internet connection is enabled. in the home menu, go to Settings > Network Settings > Internet Connection and select Enabled.
3. Scroll down to Internet Connection Settings and When prompted, "Do you want to continue?" select Yes. On the next screen, select Wireless as your connection method. Pick "Scan"
4. From the list, pick your SSID.
5.On the next screen, press right on the directional pad to continue
6. Pick your WLAN Security Setting (either WEP or WPA-PSK/WPA2-PSK). If none, pick None (and skip the next step).
7. If you selected a Security Setting, enter your Security Key or Network Key with the keyboard. Press the Start button to exit the onscreen keyboard. Press right on the directional pad to proceed to the next screen.
8. The system will check your network configuration settings and display the information. Save the Settings.
9. Test the connection on the next screen.
10. When the test is complete (usually less than a minute), it will display the results ("Succeeded" or "Failed"). If you have successfully connected to your network, Congratulations, you have completed the network setup process.
Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Ps3 and test for proper response.
The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to.
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
Feb 07, 2011 | D-Link DIR-600 Router
Where do I get my security code?
Hi Kmweidows,
If you want to get the Network Key or Security Code you need to access the Wireless Settings Page of your Router. To access your router just open a Browser then type 192.168.1.1, Username is admin password is admin. Go to the WLAN Settings Page and go to Security. Personalize the Passphrase, Network Key or Security Code so that you can easily remember it.
Rate me if this helps so I can help others. Thanks for using Fixya.
Feb 05, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I cannot connect to the internet with my wireless router MSI RG60SE. I keep getting an error and to insert a security key. How can i get this security key?
You need to access the router and look for the network key. For you to access your router you need to type 192.168.1.1 to he address bar of your browser and it will ask you for a username and password. The default username is "admin" and the default password is admin. Go to the router settings page and check the Network Key (Security Key). You can also personalize the network key for you to easily remember it.
Jan 27, 2011 | MSI (MS6848) Wireless Router
How do I lock my Dell TruMobile 2300 wireless router to keep the neighbors from getting access to my wireless internet connection
press win key + r
under run type cmd
on the command prompt type ipconfig
not down your defaut gateway.
type it in your web browser, and then enter the correct user name and password for the router.(i u dont know the user name leave it blank or try admin for both user name and password or its combination o call dell for it)
Create a unique password on your router : Once you have logged into your router, the first thing you should do to secure your network is to change the default password* of the router to something more secure.
This will prevent others from accessing the router and you can easily maintain the security settings that you want. You can change the password from the Administration settings on your router’s settings page. The default values are generally admin / password.
Change your Network’s SSID name:
The SSID (or Wireless Network Name) of your Wireless Router is usually pre-defined as "default" or is set as the brand name of the router (e.g., linksys). Although this will not make your network inherently* more secure, changing the SSID name of your network is a good idea as it will make it more obvious for others to know which network they are connecting to.
This setting is usually under the basic wireless settings in your router’s settings page. Once this is set, you will always be sure that you are connecting to the correct Wireless network even if there are multiple wireless networks in your area. Don’t use your name, home address or other personal information in the SSID name.
This is sufficient to secure your router from other to use it.
Aug 11, 2010 | Dell TrueMobile 2300 Wireless Router...
HOW TO MAKE MY D LINK 624 ROUTER SECURE
Log into the router and go to security. there set an encryption key.
Here is the user guide:
http://www.scribd.com/doc/2091490/DI624-manual
Sep 16, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Jun 21, 2009 | Zyxel (91-004-361002) Wireless Router
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
67 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
