Question about Sport & Outdoor - Others
I have a 52RF 12volt Lazer II Whisper guide Propulsion system Power Plus trolling motor (FFZ70663) that was given to me. It needs a foot pedal what are my options? Am I better off buying new?
  • 157 Answers
SOURCE: minn-kota 865 autopilot
Hello dtspins2. Your footswitch is stuck. Disconnect the DC. Remove the bottom of the foot control, check the wiring for insulation broken off and wires shorting out, and disconnect a wire(note color of wires) from switch, reconnect power to confirm motor don't run. Remove the switch and contact your local electrical supply store(may cost less) or marine store for replacement. Good Luck.
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Posted on Apr 30, 2009
  • 3 Answers
SOURCE: Minn Kota power drive trolling motor will not
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
Posted on Jul 15, 2009
SOURCE: Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Posted on Jul 24, 2009
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
How do you operate the motor? I have no details as to how the motor operates. Its a minn kota trolling motor that mounts on the front of my boat. I need to know how to operate the foot peddle.
The pedal has generally four functions:
1) Forward and back on the pedal make the motor go left and right (push forward to turn the motor right, push back to turn it left)
2) Momentary power - the little 'button' towards the top will engage the motor as long as you press down on it.
3) Selector Swith - on the side of the foot pedeal there is a switch with the following settings Con - Off - Mom (Continuous - keeps the motor going all the time, Off - well it's off and Mom - will only go when you press the momentary button).
4) Speed select - the knob on the left controlls how fast the motor goes.
It takes some getting used to but offers tremendous control and hands free operation!
Jun 25, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
May 24, 2009 | Boating
Minn Kota power drive trolling motor will not steer to the right **** huard
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Apr 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Sport & Outdoor - Others Logo
73 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
