Windows 7 will not print to my HP CP2025 saying no toner/ink
Sometimes this happens after you have changed the toner cartridge. Try turning the printer off and then back on.
Posted on Aug 02, 2012
  • 16 Answers
SOURCE: Windows 7 installs default drivers for HP DeskJet
overload the driver which has came from ur printer
Posted on Apr 17, 2010
SOURCE: how do i install a toner chip on my hp Cp2025
They're called "toner cartridges."
- See the instructions that came with your printer, but here are the basics
The HP Color LaserJet CP2550 has 4 toner cartridges, one black and three color. Only one cartridge can be changed at a time. They are on a rotating carousel. So you first press the Rotate Carousel button until the cartridge you want to change is selected, then turn off the printer, open the top, pull out the old cartridge, put in the new (being sure it's the correct color), then pull off the tab that keeps the toner from leaking.
HP's toner cart installation instructions are at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242813/c00242813.pdf
and the general manual is at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242826/c00242826.pdf
toner cart stuff starts on page 12.
If your computer will not open these pages, you need the free Adobe Reader, get it from
http://get.adobe.com/reader/
(I suggest you click to uncheck the "Free McAfee Security Scan Plus.")
Posted on Mar 18, 2010
jagesar
  • 9 Answers
SOURCE: New HP CP2025 printer prints "ghost" DVD circles between labels
hi, i work for a company who is the dealar of hp products.
you have to do a clean service of your hp printer.
after that the printer should not have ghost print any more.
Posted on Apr 17, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laserjet CP2025 stopped printing.
First thing to do is to turn off the HP. Clear out any print jobs that are sitting on your computer print que waiting to be printed. Turn the printer back on, wait about 1 minute then try printing again. If this does not work then clear the print job again and reboot your PC. Try printing again. If still you can not print then reply here with how the printer is connected to your PC. By USB cable? Ethernet? etc.
Thanks
Posted on Jun 09, 2010
Testimonial: "Great help!"
  • 137 Answers
SOURCE: Print quality problem with Windows 7 and HP DeskJet3650.
You need drivers for win 7 only for the two printers you have .some of the mfg, have not got all the bugs out as yet. Im in the same boat .had to get a new model so i could print. Check windows web. site for driver 7up dates.hope this helps
Posted on Aug 13, 2010
Why is my magenta toner smudging on HP CP2025
That cartridge is no good and needs to be replaced.
Mar 04, 2016 | HP Office Equipment & Supplies
HP color laserjet cp2025 will not print. Help.
No.
Very few printers will print if they're out of toner, even if the colour toner is exhausted and the print job is only black. Replace the empty toner and if this is the only problem, the printer will continue printing.
Jan 20, 2015 | HP Laserjet Cp2025n Printer
I have a 1" wide black smear on the right page edge when using my HP CP2025. Any ideas on how to fix this?
clean the drum if you can get to it easily and also the toner but you may need a new toner and/or drum
Nov 28, 2014 | HP Color Laserjet Cp2025 Printer Laserjet...
Hp clj 2025 cleaning
I had the same problem and it was the pick-up roller that was at fault. You can buy a new one for less than 20GBP or do what I did. Take the old one out and reverse the rubber. There are plenty of online tutorials on how to change the pick-up roller - the first one you remove. It's a two minute job. Reversing the rubber is easy. Just prize the inner clip out of the roller and put the rubber back on with the shiny side out. It worked first time and no more print errors. HP CP2025 How to Replace the Pick up Rollers and Separation Pad
Jan 20, 2014 | HP Office Equipment & Supplies
Hp corol laserjet cp2025 printing blank pages even on printer itself
Mine blank pages where caused by bad black toner, replace with OEM when in doubt.
Oct 01, 2012 | Office Equipment & Supplies
My printer will not print - Windows 7 says "toner
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back and replace the old cartridges with new ones.
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Now you will be able to print.
Oct 17, 2011 | HP LaserJet 3050 All-In-One Printer
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
My HP CP2025 printer will not print color text and color shading in Word. It prints color photos, pdfs, and paintbrush files, but will not print color in Word or Word Perfect.
I had this problem on Windows 7 64x.
The solution that finally worked for me:
1. Go to your Devices & Printers window. (from the Start menu)
2. Right-click on your HP CP2025 printer and select Printer Properties.
3. Select the Device Settings tab.
4. Scroll to the bottom where you see Device Type. It probably says "Auto Detect."
5. Click on the words "Auto Detect" to activate a drop-down menu. Select "Color". Click the Apply button.
To test if this fixes your color printing, go to the General tab and click the Print Test Page button at the bottom. The page should print the Windows logo in color at the top of the page (the rest of the page is b&w).
Note: I did not install any additional drivers from HP for this printer. Windows automatically detected it and installed HP's Universal Print Driver PCL 6.
Kudos to Ken from the HP forums for this knowledge: http://h30499.www3.hp.com/t5/Printers-LaserJet/CP2025-Won-t-Print-in-Color/td-p/1151762
Feb 10, 2011 | Office Equipment & Supplies
How to disable color printing on an hp cp2025 printer? I want to stop use of color cartridges until I specifically want to consume them.
You can adjust the device settings under the driver properties.
1. Open your printer s and hardware folder
2. Right Click on the driver for the CP2025.
3. Vista/ Xp click on properties, Win 7 Printer Properties
4. Go to the Device Settings tab
5. Under installable options:
6. Change the device type to Monochrome and apply
7. If the printer is still printing in color select automatic configuration and select configure now
For more questions please write;
Al
eliteprintersolutions@gmail.com
Jul 07, 2010 | HP Laserjet Cp2025n Printer
985 people viewed this question
jasbo
jasbo
