Question about Sony AA Nimh 2500 Mah Rechargeable Battery
How long should i charge my 2500mah batteries for the firs time??? How long should be for 1350mah??? How long should be after first time???
  • 22 Answers
The first charge is - as you suspect - longer than the normal charge in order to "wake up" a battery that may have been on the shelf for a considerable time since manufacture. Typically 30 hours for the 2500mah batteries and 16 hours for the 1350mah.
I assume that your charger charges at a rate of 140 to 160 mA. This info is usually printed on the charger itself. (Quick chargers is a different story and the chargers are usually intelligent and can regulate the charging electronically.)
If your charger charges at a rate different to the typical 140/160mA, then increase or decrease the time for charging accordingly, i.e. reduce the charge time if the charge rate is higher. A good and safe test would be to check the batteries from time to time for heating. Stop the charging as soon as you find that the batteries are heating to anything warmer than a mild temperature rise.
Posted on Jan 18, 2011
Where can I get what I need to charge the head set?
PLEASE be more precise. Firs time I hear of a CHARGEABLE headset. Usually they use batteries, and you charge them outside with their charger.
Peace-
May 01, 2016 | Shure Head Set Microphone Microphone
Tablet charger is 400mAh and Tablet battery is 4000mAh. is my charger sufficient ?
The charger is right for the battery. IF battery won't charge on it proper charger, the battery or charger is bad. Take it back or put out more $$$$$$$$$.
Aug 31, 2014 | Tablets & eReaders
Batteries run out fast
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Canon PowerShot A80 Digital Camera
Bought agojama battery drill from Macro hyper years ago, after charging few times as seldom use charger unable to charge, as it's 16 volt, unable to find replacement or get repair original charger ever...
The valtage of the battery will not make any diference, you can use an 18v battery as long as it firs the battery housing. Always remember to disconnect any battery's if not in use because if you leave the battery connected it will drain and damage it.
May 09, 2011 | Drills
My psp fat drains battery so fast
you have to get a new battery becouse the firs time you charge it you did not leave if untill it was completed(you must leave it untill it is totaly completed every singel time).HOPE I WAS USEFULL PLZZZZ RATE ME.
Jan 10, 2010 | Sony PlayStation Portable (PSP) Console
TomTom One 3rd edition - started to not charge
The TomTom One 3rd edition battery can be replaced if you are up to some work on your part with the Li-ion Battery 1350mAh Black CS-TM600SL! You will need to take off the back of the tomtom first! Now the connector on the old battery wires are not the same as on the new battery so the wires need to be spliced and soldered back together using the old connector off of the old battery! The new battery will last about 2.75 hours! Don’t try this if your unit is under warranty! The tool to take off the back can be bought at any auto parts store for just a few dollars! And you will need a flat tipped screwdriver to pry the back off! The tool needed to is a soldering iron and solder! The new battery can be bought at E TechTronics.com! Good luck if you’re up to it! The original battery is not sold anywhere that I know or can find!
Nov 01, 2009 | Tomtom ONE 3rd Edition GPS
How long the battery have to charge for firs time
doesn't take the LG long to charge. This could be due to the charger not working properly or the battery is no longer able to take a charge.
Aug 05, 2009 | LG Vu CU920 Cellular Phone
Red Flash mark while taking photo
It sounds to me like you are not waiting for the camera to charge the flash when turning the camera on or between shots. It seems you are using 1700mAh batteries and most modern digital cameras are better off using 2500mAh batteries. Your camera was released in September 2006 so it is considered "modern". With 1700mAh batteries, your flash (warm-up) recycle time time will be rather long or the amperage may not be enough to fully charge the flash unit. I highly recommend Duracell 2500mAh rechargeable batteries.
Oct 12, 2007 | Olympus FE-170 Digital Camera
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Sony AA Nimh 2500 Mah Rechargeable Battery Logo
937 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
