Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on, but does not heat food or beverage put into it
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Jan 03, 2011
The microwave is not heating the food.
When it did heat food before and you used the same settings now, the microwave must be defect.
But before you are sure, put a cup with water in the micro and try to heat that.
Dry food can't be heated in a microwave. There must be some moist in the food if you want to heat it in the microwave.
Mar 13, 2015 | Microwave Ovens
I have a GE Spcemaker XL microwave oven. It will not heat contents. Everything else works.
There are three parts that will cause this, the magnetron "heats food" and the high voltage capacitor and diode all work together to generate the high voltage along with the magnetron to warm or heat beverages.
Feb 06, 2011 | GE Microwave Ovens
Power on microwave goes off and on. Also will not heat food or beverages. Model# MH9181XMB
this is a short from the capcitor to the magnatron this is a very dangerous fault and in my expert opinion the unit is a write off and needs to be trashed
i hope this helps you
sonic boom electronics australia
please rank this advice if it helped you.
Jan 06, 2011 | Whirlpool Microwave Ovens
Microwave comes on and seems to be working properly but when it finishes and I take the food out it is still cold. It does not heat the food or beverage. The unit is new and came with the RV. It worked...
Hi, I would not mess with it...there is nothing you can easily do....find the nearest dealer and get it replaced...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 10, 2010 | Microwave Ovens
Microwave no longer heats food or beverages about 9 yrs old
heatman101
Jan 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit will no longer heat food or beverage
if there is no heating function, chances are that the Magnatron has died. repairs are just not worth the money considering that Microwaves can be oicked uo second hand and with warranty from many Cash converter stores and even some retailers who sell refurbished models from $50
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat food.
Sometimes inside the machine there is a fuse for this, if you can remove the outer case you should be able to see it, HOWEVER let me tell you that i have been in this position and have replaced the fuse and the machine then works only to die again, once this happens it is usally a sign that either the tube or a transformer is gone and it normally isnt worth getting fixed.
Mar 26, 2009 | Microwave Ovens
Lg wavedom microwave food not heating
I have a problem with my LG microwave wavedom .it makes a loud noize and i does light up and turns around but its not heating any of the food which i put in to warm. Can anyone can help please? What can i do?
Nov 20, 2008 | Microwave Ovens
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
Sep 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
48 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
