Question about HP ScanJet 2300C Flatbed Scanner
Can 2300c work with 19v power supply? - HP ScanJet 2300C Flatbed Scanner
  • 37 Answers
According to this site: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bus05611&lang=en&cc=us&contentType=SupportFAQ&prodSeriesId=73500&prodTypeId=15179 , it supports power from 9V to maximum 12V. 19V seems to be too much.
Posted on Jan 03, 2011
Would a 19v 3.16a power supply suits a lcd monitor 19v 2.6?
Yep, that should do very well. The voltage (19V) is critical - that should match exactly. The current (3.16A, 2.6A) isn't so critical, but the power supply MUST supply AT LEAST as much current as the monitor requires. The extra current capacity won't hurt anything at all, it just won't get used for anything.
Aug 01, 2014 | Acer AL1916W 19" LCD Monitor
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
What type of cable power supply do I need for a V7 L17PS monitor? I got this monitor for free but no cables came with it. Thanks
Looks like it takes a 19V 3.42A Power supply.
Look on the back of the monitor near the power jack and find where it says "input"
If it says 19V 3.42A then this is what you want:
http://cgi.ebay.com/19V-AC-DC-Adapter-Power-Video7-videoseven-L17PS-LCD-/110632100842?pt=LH_DefaultDomain_0&hash=item19c22fe3ea
Mar 25, 2011 | Videoseven L17PS 17" LCD Monitor
I have a Toshiba Satellite laptop. The original adapter is 100V, 1.l3A input and 19V, 3.95A (DC). Can I use an adapter with 100-240, 1.1A input and 19V 3.42A output?
The input voltage doesn't matter - the 100-240 just means the adaptor will work in most countries.
The output voltage is the same, and the current is only slightly lower - so as long as the plug to the laptop is the same AND has the same polarity [+ and - in the same places on the plug] then yes, you will be able to use it.
Jun 19, 2010 | Toshiba 200W SERVER POWER SUPPLY...
My Gateway laptop use AC cord with the output 19v = 3.42A. can I use the AC cord with the output 19v = 3.95A?
Yes you can use one that has an higher current rating. The system will only use what it needs. If you try to use one with an lower current rating the power supply would fail. Just check to make sure the pin out is the same..ie postive tip or negtive tip.
Feb 23, 2010 | Gateway HQRP Replacement Laptop AC Adapter...
In hp scanjet 2300c light beam is not moving
hi
when currunt scanning and then power off- this prob. apear
open scanner and put light beam to his 1st position (ofkors by hand) than power on and off 2-3 time
(when my scanner's same prob. but my scanner repairering engi. solve it by above method and i see to my eyes this. means this is my showable demo-experience) {sory for bad english}
Dec 16, 2009 | HP ScanJet 2300C Flatbed Scanner
The right power cord for a scanner
The link you offered is for a standard IEC computer power cord. (click the camera next to the item #) Problem is, if you look at the scanner, there is nowhere for that type of cord to connect. I believe the scanner requires a power adaptor, Look next to the power jack to see what voltage is required, it may be 24 volts or 30 volts for example.
Dec 29, 2008 | HP ScanJet 2300C Flatbed Scanner
Laptop not working
The Brick is the external power adapter, My acer uses model # ADP-60XB 19V X 3.16A= 60 Watts
Yours I believe is also a 19V but I believe the amps are 3.45 making yours a 65Watt power supply ac/dc adapter.
Test the voltage, if your unsure how, take it to Radio Shack and have them do it.
Mar 23, 2008 | Acer Aspire 3610 Notebook
Fujitsu laptop, touchpad stops working when connected to power adapter
dear
the consumption power ampere is symptom to your voltage of touchpad
trying installing driver touch pad again
and try to use FN + F9
oke
cropp
Mar 09, 2008 | Tablets & eReaders
HP ScanJet 2300C Flatbed Scanner Logo
55 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
