Question about Williams Allegro 88-Key Digital Piano
THere are a number of keys that are stiff or "stick" and do not play properly. IS ther a simple fix?
  • Williams Master
  • 5,603 Answers
Check if front of key is hitting the case. If it is, analyze why it is happening. If unit has been dropped this can happen. One can sometimes move the whole key assembly back slightly if this is the problem.
Posted on Jan 04, 2011
  • Tom Smith
    Tom Smith Jan 26, 2014
    The parts around the pivot joint are rotting, you have to take keyboard appart and sand or replace parts, piano is junk.
How do I fix sticky keys?
That will vary debending on what specific instrument you need help with.
Apr 15, 2015 | Music
The f and b keys after middle C does not make any sound when played. Where can I start trouble shooting?
Without knowing the make and model of the instrument we can't be of much help, although it sounds like a key contact issue. i suggest calling the manufacturer customer service department for help trouble shooting.
Sep 01, 2017 | Music
On my new (2nd hand) Yamaha YPP-50 piano, the middle D key is slightly lowered and requires a lot of strength to get sound from it. I'm wondering if its possible to fix? Maybe without going to a Yamaha...
There is a narrow padding strip that runs under all the keys going across. It is made of a type of felt. It is worn or torn in that spot. If you are careful and have some mechanical skill at opening the unit, you will see it, it should be a pretty simple fix to glue the felt back (if torn) or even to glue a small piece of felt in that spot to raise the key, which will allow full movement again so it would feel pretty close to normal again.
Mar 29, 2013 | Music
Suzuki ss-100 piano keys stick, won't play
I had an issue with my Suzuki GP-3 and I did a research and found a company called VMI Electronics (619)244-0006 they found me a technician in my area also there is a repair kit called Key Mod that fixes issues with the keys hanging low, here is the link to order it on ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
Mar 28, 2013 | Music
I have a Casio digital piano and some keys stopped working after my daughter finished "cleaning" the piano. I'm thinking maybe a fuse needs to be replaced?? Some keys plays and some do not. Any
Old reply so hopefully it's fixed. Dust or hair can get through the gaps and land on or near the contacts of the electronic key sensors. To be on the safe side (rather than doing a diy) take it in to the technicians. They'll have it fixed in a jiffy
Feb 25, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Fixing stuck keys on casio wk 200
Sounds like either the contacts are dirty or worn out. Solution clean / replace.
Jan 07, 2013 | Music
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
How is the proper way to hold timbale stick and to play with in any type of music? Because my sticks keep breaking after a short period of time playing with them.
It probably isn't the way you are holding them but rather how hard you are hitting, especially rim shots on the snare drum. Stress at the half-length point is what is hard on them.
Apr 15, 2011 | Vic Firth Timbale Sticks Large (TMB1)
A few of the flat key get stuck on the right hand. On the lower left a few the sound are loud no matter how soft you try a play. Can this be fixed?
I am sure it can be fixed. Who knows what brand or type of instrument this is...
The stuck keys are probably mechanical sticking. The loud keys are probably dirty key contacts that sense velocity.
Take unit in for servicing.
Jan 25, 2010 | Music
Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
May 17, 2009 | Music
Williams Allegro 88-Key Digital Piano Logo
272 people viewed this question
Top Williams Music Experts
Michial Gueffroy
Are you a Williams Music Expert? Answer questions, earn points and help others
