Question about Whirlpool Duet GHW9150P Front Load Washer
I cleaned out the pump .there was a penny and pieces of a carpenters pencil.I tried the washer again, the water came in the washer, the door locked after about 5 seconds the code f 11 came on, beeping started , the washer didnt start. I had the washer set on rince and spin. I cheched the pump impellor .no damage
  • 1 more comment
  • cefford Jan 03, 2011
    Did checks as requested, the water came in the washer,door locked washer did not start, f 11 code came back on and beeping sounded
    update. When i select no spin the pump work,do that mean there is a problem with the motor?
  • cefford Jan 06, 2011
    I ended by calling a repair man , he told me the problem just by the what I told him. He really knew what he was talking about. All together it cost me a little over $600.00.I will call him the future if I have problems.
  • 8,197 Answers
The f11 code means
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Here is what to look at.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Posted on Jan 04, 2011
    • Jyackle5
      Jyackle5 Jan 07, 2011
      Glad you got it fixed sorry you needed to call a repair man
      Director Badge:
      Uploaded 100 video answers.
    • 1,751 Answers
    Fl i a door latch error code. F11 is a serial communications error that is associated with either the door latch, central control unit (main computer) or associated wiring. Since you can hear a "click", and the washer works intermittently I would suspect you have a bad door latch assembly. Just to be sure you will need to check all your wiring connections going to the central control unit and door latch. To access follow these steps:
    1. Unplug the washer.
    2. Remove the three 7mm screws holding the top panel on. They are located along the top edge in the back of the washer. Once the screws are removed the top panel will slide back then lift up.
    3. The Central Control Unit (CCU) is located in the central rear of the washer. You can't miss it. Make sure all the connections are plugged in snugly. The door latch connections are located behind the front panel on the right hand side. Check ONE connection at a time.
    After checking wiring harness, run systems diagnostics test by performing the following:
    Select DRAIN/SPIN, NO/SPIN, followed by pushing any button under OPTIONS 4 times. If entered correctly the display will read "C00" and you should hear the door latch "click". The diagnostics will run through a series of tests to include FILL, AGITATE, DRAIN and SPIN functions. Since the door latch is the first step of the diagnostic sequence, the tests will not progress if the door latch fails. You can push PAUSE/CANCEL any time to end diagnostics. Run this test several times. If anything fails you will get an "F" code in the display window. If the tests all pass, the unit will shut off, followed by an audible "beep" and the CLEAN light indicator will be lit. If you get successful results, then you know you probably had a loose wire somewhere. If the test fails, I would attempt to replace the door latch before the CCU. The latch costs considerably less. The CCU can cost as much as $220 depending on where you get it.
    If you decide to replace the door latch follow these steps:
    1. Make sure washer is unplugged.
    2. Locate the wire hoop retaining ring that holds the rubber door boot on. It will be located behind the front edge of the rubber where it meets the door frame.
    3. Locate the tension spring at the 6 o'clock position and stretch the spring apart to release the hoop. Pull the hoop from the bottom first and remove from the door boot.
    4. Pull door boot from door opening and fold back inside wash tub so you can access behind the front panel of the washer.
    5. Remove the three torx screws that hold the door latch on.
    6. The door latch is seated in a plastic retainer bracket. Reach in behind front panel and carefully remove the door latch from this bracket so you can access the wire connectors.
    7. Remove wire connectors.
    8. Re-install wire connectors and latch in reverse order of how it was removed.
    9. Re-install door boot, ensuring it seated properly all the way around the door frame opening.
    10. Re-insert wire retaining hoop in the groove behind the front lip of the rubber door boot starting at the 12 o'clock position and working your way around to the 4 and 8 o'clock positions. (You may need a second set of hands for this part). While holding downward tension on the hoop to keep it seated, stretch the spring apart enough to snap the remaining part of the hoop back into place at the bottom of the door opening.
    Run system diagnostics again to see if the latch functions properly and all tests pass. Good luck to you and I hope this helps you.
    Posted on Jan 03, 2011
    • nikos pappas Jan 03, 2011
      I m sorry to hear that
      Check the wire harness connections between the CCU, the MCU and Drive
      Motor. Make sure all connections are attached and making good contact.
      Check for any broken wires or connector pins.
    The pump is not pumping water when in drain cycle and "Pump Blocked?" error is displayed. The washer has been drained and the pump cleared of debris (penny, toothpick and two small rectangular...
    Hello & Welcome to FixYa
    If you have cleaned it completely and nothing is blocking the drain pump assembly then it means that the drain pump is bad and needs replacement. Please get back to me if you have any other questions.
    Kevin
    Jul 25, 2011 | Bosch Axxis WFL 2060 Front Load Washer
    GE Washer, Model GBVH5140HWW. Door seal failed and water in washing machine leaked into the base of the washing machine. Removed the front panel, replaced the door seal, dried up the water in the machine...
    The seal is likely not installed correctly. What is happening is the latch for the lock is trying to hook and it is being blocked so it doesn't actually lock. After so many tries the machine goes into an abort mode where it washes out all the water and stands by for it to be fixed. If you put some pressure on the door (closing it) while it is trying to lock, it likely will lock and then run. It is basically an adjustment issue. It is also possible that something with the lock mechanism is broken or out of adjustment causing the leaking to begin with and that is actually the area that needs attention rather than replacing the door seal. Door seals rarely fail unless they are physically damaged somehow.
    Jun 02, 2011 | GE WSXH208A Front Load Washer
    My whirlpool duet washer will not complete a cycle, it isn't spinning/draining and now door is locked & will not open. I tried unplugging it & plugging it back in but no luck..... What should I...
    While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
    Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
    Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
    How abt a nice rating for the free help? Thnks
    May 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    WATER PUMP ON DUET
    Was easy to remove clamps with a pair of Channel-lock pliers
    Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite HE4t cycle time blinking but nothing happening
    remove lower panel reach up to lock area and pull down on tab to release door remove as much water as possible go back to bottom and turn pump clean out to left HAVE PLENTY OF TOWELS HANDY..clean pump trap out and reinstall
    Nov 09, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
    Error Code FL
    I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was clogged with a penny. The original external drain hose has a valve that keeps water from coming back into the washing machine. The penny had lodged in the vlave. On the second occassion, a piece of a hankerchief was caught in the drain pump. This pump has a "propeller" that pulls the water out of the washing machine and pushes it out to the external drain hose. I took it off the drain pump motor and tried to clean it. The original pump is solid and you can't take it apart to clean it. I did the best I could, then put it back on. It made a loud noise when draining. Whirlpool no longer sales just the drain pump, you have to buy a complete new pump and motor combo. It costs about $70 on e-bay (new). It is fairly easy to install (30 min). The good thing about the new pump is that you can take the cover of the pump off without taking the pump motor off. The third time I took the pumpef cover off and found a penny lodged in the pump. After taking it out, the machine ran well.
    Note 1: A good way to drain your washing machine is to take a hose pipe and put it in the top of the machine and then use a manual air mattress pump (in reverse mode) on the opposite end of the hose that you put outside. After several pumps on the air mattress pump sucking the water through the hose, you will create a suction that will keep flowing until much of the water is out of your tub. Be ready with several containers to catch the rest of the water when you take the hoses off the pump.
    Note 2: Check pockets well to keep things from getting into the drain system. Use a delicate wash bag (a mesh bag) to wash undergarmets, hose, hankerchiefs, and other thin items that might get sucked into the drain system.
    Mar 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
    Won't drain
    Remove the lower kick panel under the door and you should see the drain pump located directly under the wash tub. There is a screw off cap that can be removed to access the clean out trap. It is strongly recommended that you drain all residual water from the wash tub BEFORE you remove the drain pump cap, or you will have about a gallon of water to clean up. The residual water can easily be removed with the use of a wet/dry shop vac. Just remove the drain hose from the standpipe and pull a vacuum through the line with the shop vac. This will save you time later in clean up. If you do not have a shop vac, grab some old towels and place them under and around the drain pump. This will help in controlling the amount of water spill.
    PS This residual water is normal in washing machines and should not be considered a problem unless the water is visible in the tub. Residual water generally sits between the outer tub and wash basket in the drain lines. This is truw with top loaders as well. Most front loaders will start a brief drain cycle at the beginning of the wash cycle to get rid of this residual standing water to prevent stagnant water from getting on your clothes. Just thought you might like to know...
    Jan 27, 2008 | Kenmore 46462 Front Load Washer
    No washing
    Hi, mine was getting to this point. After cleaning the filter all went back to normal. If you have not tried it, remove the three phillips head screws on the front bottom panel. You will see a plastic piece on the right hand side. You can unscrew it with your hand (drain water into shallow cake pan). Once water stops coming out, remove filter all the way and clean the pens, pencils, change, lots of lint, etc... out and put it back in. All should work well after this. Thanks, Greg
    Dec 16, 2007 | GE Energy Star WCVH6260F Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    49 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
