Question about Honda Garden
Honda HRR mower 8 months old. Transmission locks up when pulling mower in reverse.
3 Suggested Answers
  • 12 Answers
SOURCE: the wheels lock up when i pull my lawnmower backwards
if you hold the clutch down to shift the gears after you release it if it doesn't move in reverse you have a gearbox problem and the easiest way would be to take it to a shop to have them fix it, it may not be too cheap but it is cheaper than getting the parts taking it apart and not being able to put it back together right. if you try to fix it yourself you could really mess it up and then it would end up costing you more than it would have to have just taken to the shop to start with.
Posted on Jun 15, 2009
mowerman1857
  • 389 Answers
SOURCE: My mower (HRR) was hard to start and then would
It sounds like you are in need of a valve job on it. You can check this by removing the spark plug and holding a finger or thumb tightly over the hole while someone pulls the starter cord. If it doesn't literally "pop" your finger off the hole, you have a leaking valve and need to do a valve job or at the very least a valve adjustment
Posted on Oct 26, 2009
Cub cadet xt2 reverse just got slow, why
Sounds like it may be a transmission issue. I would think warranty may cover it.
Sep 14, 2017 | Cub Cadet Garden
I have a Honda lawn mower mod.hrr it will not
It sounds like the carb choke is not working. If your model has a primer bulb, check it for cracks or holes, as this will let your engine draw air instead of fuel into the carb fuel section and keep it from running. Good Luck
Sep 04, 2014 | Garden
Honda HRR Mower
remove the carby are clean the corrosion from the main jet and needle seat hole
check for fuel flow through the metal tap as they corrode internally blocking fuel
Sep 17, 2017 | Garden
Automatic transmission reverse not working
Try flushing the fluid. 2 1/2 quarts come out easily with the drain plug at the driver side. Add only Honda approved fluid. It is OLD dextron and $8 a quart. There is no filter on a Honda but you could add one on the return line from the radiator /cooler. Use Lucas conditioner as a last resort before replacing the solenoids/transmission. My CL had blocked filter mesh screens at the Torque Converter lock-up solenoids.
Oct 20, 2010 | 1987 Honda Prelude
Honda HRB 216 Lawn Mower Manual
Sure you don't mean HRR? A number of models can by downloaded from the HRR from:
http://lawnandgarden.manualsonline.com/manuals/
Search using the Lawn and Garden Product Manual Finder which can be found on the left side.
Oct 02, 2010 | Garden
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Oct 26, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
The wheels lock up when i pull my lawnmower backwards
Jun 15, 2009 | Oregon Scientific Oregon Gator Mulcher...
Garden Logo
148 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
