Question about Dryers
Indesit is70cuk the water tank is not filling. All the water is staying at the back of the machine. I have checked for blockages in the pipes and followed the instruction book.Any help please
  • 1 more comment
  • Dana Newcombe
    Dana Newcombe Jan 03, 2011
    Is this a clothes "dryer"?
  • juliewrexham Jan 03, 2011
    yes
  • Dana Newcombe
    Is the dryer on a very level surface? This could be a simple case of overloading otherwise.
    President:
  • 1,564 Answers
There is also the very obvious solution that the heating element be it gas or electric is not operating correctly, check to see if one of the two breakers(for electric) or the gas burner is functioning correctly.
Posted on Jan 03, 2011
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
Too much water going into the machine indesit wil103 water coming out the drawer when the drum turns.
Could try pressure switch/ clean the pipe feeding it check for hole in it causing air leak and pressure drop, make fill valve overfill
Apr 20, 2010 | Indesit W 123 Front Load Washer
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
Diplomat apd8703 filling problems
If I were u, I wud check the hose or chamber where the water level switch hose is terminated for any blockage or obstruction there as this is often the cause of the prob, u were certainly on the right track.
Plz rate my solution, and feel free to leave a comment.
Thanks.
Jan 01, 2009 | Indesit W 123 Front Load Washer
Indesit w123 front load
would check pressure switch and the pipe that goes down to the drum for blockages if not may be faulty water valve unplug first regards jason
Apr 28, 2008 | Indesit W 123 Front Load Washer
Indesit w123
the holes above the drawer may be blocked. remove the drawer and scrub the holes with a stiff washing up brush rinse away then try again.
Jun 21, 2007 | Indesit W 123 Front Load Washer
WD12 Indesit washer/dryer
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: Timer- If your washing machine fills with water and begins agitating, but the timer won't advance. Then you need to replace the timer. Water supply problem- If water doesn't enter the machine when you start the process- check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open). Check that water entrance valve works (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it doesn't get power, it seems that the problem is with the timer unit. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
Mar 22, 2006 | Indesit W 123 Front Load Washer
Dryers Logo
119 people viewed this question
Top Dryers Experts
