Question about Cell Phones
How to turn up the volume on jcb mobile phone
Delete messages from a jcb tp909pro smart
hi does anybody know how to delete messages from the pro smart phone jcb,
Feb 07, 2013 | HP Jcb Toughphone Pro-Smart Ip67 Tp909...
How do unlock jcb sitemaster 2
Solution:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 28, 2012 | Sendo Sonim XP1 JCB phone extreme...
Need a user manual for JCB toughphone TP909
http://luputech.com/luputech/jcb-toughphone/manualer/
hi Here you can find the Instruction manual for all JCB Phones, Pro smart is in swedish, but u can use google translate ;)
Jul 17, 2012 | HP Jcb Toughphone Pro-Smart Ip67 Tp909...
Jcb tradesman phone only shows numbers on texts not names
I bought one of the JCB Tradesman Toughphones off e-bay and had the same issue.
I notice that newly created contacts work fine. The problem is with about 90% of the contacts that were on the sim card even if I moved them to phone memory. If I open each contact and resave it with a dot or something after the name it works fine and then displays the callers/texters name ok. It's a bit laborious to go through them all one by one but it's a once off chore
Nov 02, 2011 | Sendo Sonim XP1 JCB phone extreme...
My mobile volume is very low please tell me how can i increase my mobile volume
you can turn your volume up on your device two different ways, the first way is on the side of the phone there is a volume key and the other is found by going to settings and volume
Oct 08, 2010 | Cell Phones
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
JCB phone manuelgot phone from e-bay BUT did not come with a manuel or any instractions
You can get the JCB phone manual from the below mentioned link,
http://rapidlibrary.com/index.php?q=jcb+manual
EBJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 05, 2009 | Cell Phones
Cell Phones Logo
166 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
