Samsung toploader WA13G7Q1 washing machine does not go into spin mode. 6E error code is displayed.
  • 1294 Answers
SOURCE: washing machine
Probable your outlet filter is clogged, find this out from your manual, clean and refit. Plug off the wall first. This requires periodic cleaning, according to your usage.
Posted on Sep 11, 2007
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
SOURCE: i have a j1453 washing
6E error means ambient temperature is too low.
A problem that occurs when the potentiometer connected in series with the thermistor on the microprocessor board is damaged.
for more details try this link:-
http://applianceguru.com/view_topic.php?id=3721&forum_id=2&jump_to=95478
As this is under generic problems on all washing machines, the link will surely help.
Posted on Dec 13, 2008
  • 136 Answers
SOURCE: samsung wa13g7q1 gives se error
Please check the following :
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Posted on Jan 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
I have a samsung toploader wa13g7q1... it uses approximately 420 litres of water per wash.. full load... is this normal?
Do something good for all your skin. Use natural natual skin care products. These do not contain harmful chemicals, unlike synthetic ones that damage your skin over
http://www.toptryloburn.com/vita-luminance/
Mar 29, 2016 | Samsung Washing Machines
I have Samsung J845 front loader washing machine. The error code bE or 6E is showing up. It won't spin at all and barely drains
Possibly a short circuit to motor or PCB
Requires a competent repair engineer to fix.
Check mains supply
Check main control module
Check main drive motor
Mar 22, 2016 | Samsung Washing Machines
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
My Samsung washing machine p1453 stops after 10 mins washing and comes up with code error 6E which is not in the manual
They usually stop with an unbalance load or If its a newer model and u use h.e detergent or suppose to be using it, and if u use it or another detergent to much , to heavy many newer washer have a suds sensor and when it detects to much detergent it will shut u down
Oct 03, 2014 | Washing Machines
Samsung p1453 error code 6e?
6e fault is saying that the temperature is not high enough, this is most likely a malfunctioning temperature sensor or an issue inside the electronics.
Mar 10, 2012 | Computers & Internet
I have error 6E on my samsung washer
If during the spin cycle, the error code could be an error with the printed circuit board assembly of the washer. This means that the temperature readings are incorrect and the error will continue to display.
E6 error code indicates that the water heater is heating water too fast. Press the power button once to clear the error and finish the cycle before repair.
Check this link with additional info: original/457.jpg?1285349415
Hope this helps.
Apr 18, 2011 | Washing Machines
What is erro code 6e on a samsung washing machine
Don"t worry too much about the error code, press pause, and then press pause again, the cycle should continue. If the counter does not countdown, ideally,as long as your washing is in the machine for 30-35 mins that should be ample time, then press pause and put your dial on the final cycle from rinse to spin, if this does not work, try picking a longer wash cycle, leave for 30-35 mins, then press pause and fast-track to your final stage of rinse to spin, Good Luck!
Apr 16, 2011 | Washing Machines
Wa13g7q1 washes but doesn't want to spin; code de appears with an alarm, pls help
Replace the pressure switch, and run a cup of white vinegar thru a cycle with no laundry in the unit.
Sep 22, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Error code ( IE ) on my samsung washing machine model wa13g7q1
Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Willnot spin, error code 6e
lg wf-t851 will not spin. displays 6e error code
May 23, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
