Question about Vacuums
Motor on Eureka vaccum is suddenly very loud. I've changed all the filters and the belt.
  • 694 Answers
The likeliest causes would be a large item sucked up and into the fan, causing a loud rattling noise, or a piece of the fan broke, resulting in the same noise. This means replacing the fan assembly.
The armature brushes could also be worn down to the point of causing the brush holders to contact the armature, which will, and probably has, ruin the motor. A replacement of the motor is necessary.
Cost of repair/replacement would probably be higher than the vacuum is worth.
Posted on Jan 03, 2011
Testimonial: "Thank you for your feedback. I appreciate the advice and quick turnaround in your response."
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
What is the cause of the loud noise in my vaccum it's a eureka boss bagless
If it's a rattling type noise, its possibly something in the fan assembly, including a broken off piece of the fan.
It could also be something loose near the roller brush, including a piece of the belt.
Nov 18, 2010 | Eureka 5856BVZ Boss Bagless Upright...
It vaccum but it is really loud i dont know if there is something stuck in it or what is causing the problem.
It could be due to a stretched or worn drive belt. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
I have a eureka boss capture bagless
by the pic, its not an eureka, its a hoover w.t. s.p . if you removed the clog and still nothing, change the bag or clean the washable filter at the bottom of the bag.(belts should be changed every 6 months)
Jul 20, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Eureka altima stopped power mid vaccuming, have changed outlits
make sure all your filters are clean,try to turn the brush roller by hand a few times if it turns real freely then the belt is broke.if it is reall hard to turn then you have something wrapped around the ends of the roller where the bearings are.your motor guard might be keeping it from running because it got too hot take the brush roller out and the belt let it cool down for 20 minutes then try it without the roller and belt.you should be able to take the ends of the roller off by just pulling out on them so you can remove what ever is in there
Mar 21, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Vacuums Logo
204 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
