Question about HP JetDirect 610N Print Server
We believe the problem with our LaserJet 5000 GN is the JetDirect 610N network connection on the back. It prints its own internal documents just fine, so we know it's not that. And the network itself seems to be fine (other connections working great). Do you have any good info on the JetDirect 610N and how we can get another or fix this one?
  • 42 Answers
New Part Number is J7934A it is newer version and costs about $75.00 . To test the jet direct, press menu and then information, print the configuration page, if more then 1 sheet comes out 1 will be for the jet direct if this prints there is nothing wrong with the Jet Direct. however if you are printing through the network and you are getting any type of special characters like $%^ it is most likely a driver issue, uninstall the printer and reinstall using PCL 6. You can go to HP's wesite for driver support. Hope this helps.
Posted on Jan 17, 2011
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
I have both green light next to the rj45 on my jet direct 610n, but my jet direct doe not show when I print the configuration page, I tried cold reset didn't help. Any idea howni might be able to...
If your JetDirect Ethernet card does not show up on the configuration page then the JetDirest is bad. This is somewhat common with the 610N cards. You will need a new card. They are cheap to buy just about anywhere including Ebay. I have replaced dozens of them over the years.
Sep 12, 2010 | HP LaserJet 4100tn Printer
Is it possible to install the Post Script drivers for a Laserjet 5000 printer? Also how can I use that printer within my network to print from other PC's
Yes, hp provides a Universal Postcript Driver.
1) Go to hp.com and click on Support & Drivers at the top of the home page. In Step 1, select Dowload Drivers & Software. In Step 2, Type into the window LJ5000 and click Go.
2) Select Laserjet 5000
3) Select your operating system, e.g. Windows XP, or Vista, etc.
4) Scroll down to the driver tables. Look for Universal Postscript Driver for Windows and click on Download.
5) Install the driver.
As for the network, I assume this is a Laserjet 5000, NOT a 5000N (which means it has an Embedded network card inside). If this is the case, you will need to add a JetDirect card into the printer. Then you will be able to install it to the network and print from other PCs.
On the other hand, if yours IS a network printer, you will merely need to install the printer to your network.
1) Plug you network cable into the printer.
2) Power the printer on.
3) After the printer comes to READY, wait for about 3 minutes.
4) Go to the printer's onboard menu and scroll to INFORMATION and select that menu.
5) Scroll down to "PRINT CONFIGURATION PAGE".
6) On the Config Page, look for the Embedded JetDirect page, and look in the left column for IP Address. It should be from your network.
7) Look next for Configured by: DHCP.
8) If you go to a PC that is on the same network, type the IP address for the config page into the web browser address window and press Enter key. You should see your printer "Laserjet 5000", and can from here do all knids of settings if you choose.
You will need to install the driver on each PC, or install the driver onto the network server as well.
May 01, 2010 | Office Equipment & Supplies
Respected Sir We are having HP Laser Jet Printer 4600dn it is shwoing error 82.0180 E10 2 Error? What i have to do now
You have a failed JetDirect network card (look on back where the network cable plugs in) usually a grey or white slot card with 2 thumb screws (ex: 610n). If this is add-in card, you can buy a replacement and reinstall it. If the network port is built onto the printers fomatter (main board), then you need an authorized HP repair center to replace and set the serial number through service mode.
Dec 19, 2009 | HP LaserJet 4600dn Color Printer
Working HP Laserjet 5000 GN printer to give away
Thats a big printer! Have you thought about donating it to a local church, or preschool? Both do a lot off printing and have a tight budget. That will keep it out of a landfill.
Jul 08, 2009 | Office Equipment & Supplies
Need to install network printer to DLink Router
It has been a few months, so you probably have resolved this -- but just in case someone else is looking to find out the IP address on the internal print server of an HP Laserjet 4000n printer so they can set it up on their network, here are the steps to find the IP address on the HP JetDirect internal print server:
1. Have the Ethernet cable plugged in to the router and the JetDirect 600n card and power it on.
2. Make sure display screen on printer says "Ready".
3. Press the Menu button on the printer until you see Information Menu.
4, Press the Item button on the right (+) side until you see Print Configuration page.
5. Press the Select button and a configuration page should print.
One page is the printer's configuration and the other page is the print server configuration page. If you have a good JetDirect card, and good connection to your router, the IP address of the printer, plus its subnet mask and default gateway should be shown on the EIO configuration page.
If the printer has been manually set with a static IP address, subnet mask and default gateway that will not work on your network, you will see the settings will indicate "Configured by" User Specified.
To clear those settings and allow DHCP setting, perform a cold reset on the JetDirect card, by powering off the printer, holding down the green "Go" button and powering it back on until you see "COLD RESET," let go of the green Go button, wait a couple of minutes, then run another configuration page to see the freshly assigned DHCP address of the print server.
Hope this helps someone.
Mar 14, 2009 | HP JetDirect 600N Print Server
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
610N dissapeared no lights, empty EIO, reset no help
If you're seeing it intermittently, try the following:
-remove it completely
-power cycle the printer with it out
-check your contacts (be sure no bent pins, etc)
-Try it in a different slot if you have one (most HP's with an internal jetdirect have 2-3 EIO slots, but since you don't mention what model printer you have I don't know for sure).
If it's not talking after all that, likely the jetdirect is actually dead. It's been known to happen. I wouldn't waste the money on a replacement, you'll have better luck getting an external card and it'll be cheaper, too.
HP sells both the JetDirect 170X and 175X externals; there's also the Linksys PSUS4, D-Link DP-300U, TrendNet TE100-P1P, or Netgear PS101NA. Price will vary between $45-80.
Mar 27, 2007 | HP JetDirect 610N Print Server
HP JetDirect 610N Print Server Logo
617 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
