Question about Hoover Washing Machines
My delay start button keeps flashing on my Hoover Optima HNL6166 washing machine and won't let me cancel it and reset a programme, it also will not drain the water but the drum is going round
4 Suggested Answers
  • 108 Answers
SOURCE: No draining on washing machine
I am not an expert on hoover - mainly hotpoint...but..
To empty your machine of water reset the programmer to Final spin. the machine should empty normally.
On hotpoint if you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Posted on Feb 22, 2008
  • 6277 Answers
SOURCE: hoover nextra optima HNL6166 Started a
Hi Steve from retired Englishman in SW France,
How to obtain another manual is at the bottom - bit of FixYa/ John C added value;-0)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 09, 2011
  • 6277 Answers
SOURCE: My Hoover Nextra Optima will
John C
Posted on Sep 18, 2011
How to reset a Kenmore model 2661532210 washing machine
try this.if it does not work then go to this link and see if it helps you out...... Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website............
Reset Buttons for Washing Machines
Dec 08, 2016 | Kenmore Washing Machines
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
Sep 16, 2015 | Electrolux Dishwashers
Programme not finished on/off button flashing won,t restart
As you do not specify model, itis difficult to give you an accurate answer to your problem.
If it has a start/cancel, or reset button, then switch washer off, wait a few seconds, then switch on again.
Press and hold start cancel button for 3 seconds, and then try to programme it again.
This is not guaranteed to solve the problem ,as I say, you do not specfy the model number.
Feb 02, 2010 | Hotpoint Washing Machines
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Water wont drain away but there is a time delay button flashing but it is not seleccting a time.how do i cancell this program so i can drain water from machine.the machine model is a hoover hnl 842
unplug for 40 minutes to reset the controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Washing Machines
How to cancel pragram after wash has started
hold the start button in until disply shows programme cancelled - it'll come after programme paused just don't let go or it'll only pause
Dec 20, 2008 | Hoover AAA160 Front Load Washer
Regards
Feb 21, 2008 | Washing Machines
Washing Machines Logo
247 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
