Question about Samsung LN-S3251D 32 in. LCD HDTV
I have a Samsung LNS3251DX/XAA 32 inch LCD TV. After almost 2 years to the day, the TV just stopped turning on. Absolutely nothing will happen when you push the on/off button in the front or use the remote. No standby light will go on, no sounds will be made, the TV is dead. Does anyone have and suggestions how to fix this? can it be the power supply board or is it the main? thanks!
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Posted on Nov 24, 2008
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
  • 280 Answers
SOURCE: HARWA LC37W18S LCD TV using KAS200-5S241812XLS
Check all the caps on PSB. if any look puffed , replace them. If you are getting 14volts to the ivnerter board PS is good and the inverter is bad.. good luck
Posted on Apr 10, 2009
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
Samsung model LNS3251DX/XAA, Version SP02. Video just went out, audio is fine, but screen is black. Do these have replacement bulbs available, or is this a doorstop?
not there is not lamp avelible for this unit because is a lcd tv , but ur problem is on the power supply , u have a bad diode , u would need a voltimeter to check the doede on the power supply the part # for this unit is 0402-001415 good look
Nov 03, 2010 | Samsung Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Sep 14, 2009 | Samsung LNT2642H 26 in. LCD Television
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LN-S3251D 32 in. LCD HDTV Logo
403 people viewed this question
Jerry Greenberg
Jerry Greenberg
