Question about Brother MFC 7840W Printer
My Brother MFC7840W goes to sleep and will only wake it up and print if computer is rebooted. It didn't used to do this. Please help. Thanks.
  • 60 Answers
SOURCE: Printer doesnt come out of sleep mode (Brother MFC7420)
I'd be happy to give you the solution to this problem :)
You'll want to go into the menu and choose these options: 1,6, and 2. The final stop should give you the sleep menu.
The printer is setup for a default of 5 minutes. But you can change it from 00 to 99 minutes. To just shut it off, press the Options and Start button simultaneously and that will do the trick.
Here is the link to the manual: http://www.brother.ca/en/products/pdf/manuals/MFC7820N-UG.pdf
If I wasn't specific enough, the solution is on page 2-6
-Ernest
Posted on May 01, 2008
frcs68
  • 1605 Answers
SOURCE: MFC6490 PRINTER goes offline. It does not print
go to control panel>> adminstrative tools>> services
select the printer spool and right click. stop the spool. go back to the printer properties and delete the print job. restart the print spool.
Posted on May 29, 2009
geo_jonas
  • 555 Answers
SOURCE: cant t my brother mfc7840w printer working on my
hello,
please try to check if the printer driver of your printer can support your current operating system you are using. Need to know the operating system supported with the driver of your printer.
Thanks
Posted on Aug 18, 2009
  • 37 Answers
SOURCE: My Brother MFC 9440 CN Printer won't wake up once
Have you recently made any changes to your PC; upgraded any software? The problem could be your driver and you may want to get the latest one, but it sounds like the firmware needs to be updated. A repair facility would be able to take care of that for you.
Posted on Oct 09, 2009
  • 159 Answers
SOURCE: My brother MFC7840w will not send faxes.
There are two jacks side-by-side. Be sure the phone line is plugged into the one marked LINE, not the EXT. jack, which is for extension phones or answering machines. OK, it's not that. Don't be mad - we had to check.
Most of the telephone circuitry is on the Main Board, but first the line is fed though a Network Control Unit, part number LG5857001. That NCU board is fairly cheap, but you don't know whether it's the problem until you replace it. NCU Board problems are often visible with a good magnifier: broken solder joints & stuff. Problems on the Main Board (part no. LT0226001) are more common and more expensive - maybe more expensive than replacing the machine.
Brother has a one-year warranty on these. If it's just past that, you might still be able to talk them into sending a Work Order to your nearest Brother servicer to do it free.
Posted on Jan 27, 2010
Backlight
On a Desktop? Reboot, Open Control Panel, Power Options, set to High Performance, Advanced Power settings. Set Hibernate and Sleep to Never. Shut down your computer when not in use, it will last longer and a reboot everyday will reset the machine.
Jan 16, 2013 | Dell Inspiron Computers & Internet
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
How do I get my brotherMFC-7220 printer off sleep mode
Turning it on and off should get it out of sleep mode, or just sending a print job to the printer should also wake it up. If that doesn't work you can try unplugging the printer from the power source for 40 seconds, then replug it in. If it is STILL stuck in sleep mode then something has failed on the printer itself.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 13, 2010 | Brother MFC-7220 All-In-One Laser Printer
Screen does wake with computer
go 2 control panel and select power management and configre ur monitor time when it go to sleep mode. thanks
Jul 29, 2009 | Computers & Internet
Sleeps to often
WHEN YOU AREW NOT USING THE FAX MACHINE FOR AWAHILE IT GOESE INTO MODE, PUSH ANY BUTTON TO WAKE IT UP, THE SAME FOR INCOMING FAXS IT WILL WAKE UP BY ITSELF., GOOD LUCK
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
How can we exit Sleep mode?
what was the password to remove form the sleep mode
Aug 28, 2008 | Brother IntelliFAX 4100 Laser Fax
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
-Ernest
Apr 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7840W Printer Logo
649 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
