Question about Maxtor 6Y080P0 80GB Ultra ATA133 7200rpm 8MB Hard Drive (HDMX80A7P)
My hd 6y080p0 maxtor shows in device manager but does not show in explorer as a usable drive. I am trying to use this HD as a slave drive.
  • Brian Reitz
    Brian Reitz Jan 03, 2011
    What Operating System are you running?
    Do you know the motherboard make/model?
    Are both hard drives (current master and new slave) connected on the same cable?
    President:
  • 1,812 Answers
You will just Change the pata cable as new or fit to HDD tightly and restart the PC.If the problem is same, your HDD parturition has been corrupted unfortunately. so you need to format again from >my computer>manege>disk manager >and format.
If you don't want to loss data dowmnload ontrack boot cd and recover the partition.
http://www.downtr.net/297918-ontrack-easyrecovery-professional-621.html
Regards
Shibuda
Posted on Jan 03, 2011
I installed a Maxtor 4R080L0 as a slave drive. My Windows Explorer (XP) cannot "see" the drive. - It is recognized by the BIOS. - It is properly listed in the Device Manager and 'running properly' - Win...
You will need to go into the control panel, administrator, and then disk drive manager. once there you will need to initialize the new drive and then format the drive before the system will see it. Format using the NTFS file system only if you are using XP, After the format is completed reboot the system and your new slave drive should show up just fine and you will be able to log into it or use explorer to view it.
Apr 14, 2017 | Maxtor QuickView (4r080l0-qv) 80 GB Hard...
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
HD Maxtor model 91360Ua
Hi fkjedi,
Most Maxtor drives all use the same configuration, but HERE a link to explain and show you how to configure each drive. You can print it out and save this for future use.
Thanks
Please leave a rating based on this solution!
Mark
Mar 28, 2009 | Maxtor Hard Drive
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
I have a dell optiplex, the primary HD is a Western Digital 160gb Sata I also have a LG DVD/RW combo drive set to master on the IDE channel. I recently attempted to add a 2nd ide maxtor HD and for the...
Hi there
When you into the bios settings choose default bios settings and save, reboot the machine and have a look in the bios again to see if the bios has picked the drive up
Good luck and kind regards
Jan 07, 2009 | Computers & Internet
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Can't format hd
We need the make and type of computer and OS in use to guide us.
May 17, 2017 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Maxtor 6Y080P0 80GB Ultra ATA133 7200rpm 8MB Hard Drive (HDMX80A7P) Logo
110 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
