The possible issue may be some door sensor broken or work abnormal. Double check three door sensors, especially for two door sensors who are working on normal close state.
It is not the fault with the fan but the trigger to the fan is shorted. It can be the DOOR SWITCH or the Transistor switch from the board. A fault or error on the processor cannot be ruled out. Clean the main board and reset.
Happened to my 2005 Advantium120 twice, both times after extended cooking/simmering on the cooktop (17" below). Solution was to leave unplugged for a good 48 hours (to dry out?) then plug in again and all is good. GE says to either raise the microwave 4" or stop boiling pasta on the stove, neither a good solution. Good luck!
You can find helpful GE exploded views and order GE parts
here, and download GE owner's manuals and
installation instructions
here. We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
