Question about HP Photosmart C6280 Printer
HP Photosmart C6300 ink system failure - will not print. What can I do?
Roop1980
  • 228 Answers
SOURCE: Ink System Failure (Error 0xc05d1381)
To resolve the issue, use the following steps.
Step one: Remove the cartridges
Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
Open the product cover and remove the cartridges.
Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
Disconnect the power cord from the back of the product.
Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
Open the product cover and reinstall the cartridges.
Close the cover and print a calibration page, if prompted.
Print a self test report to make sure that the product can print.
Reconnect the USB cable between the product and the computer.
Try to print a document from an application on the computer.
If the issue has not been resolved, contact HP to review these troubleshooting steps and evaluate if the product needs to be serviced.
Posted on Apr 11, 2009
Joed911
  • 4338 Answers
SOURCE: Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 21, 2009
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
smwsolutions
  • 73 Answers
SOURCE: printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Posted on Jul 19, 2009
  • 3 Answers
SOURCE: hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Posted on Feb 06, 2010
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
Jun 24, 2014 | United Stationers HP Photosmart C8180...
Hello, I have a HP Photosmart D5460 Printer and all I did was change the printer cartridge and now I cannot get the printer to print can you please help
This particular issue, i.e. 'ink system failure' with the error code starting with 0xc19a for teh Photosmart C6300, D5400 and D7500 is being handled by the Level 2 techs at HP and all L1 agents have been instructed to transfer the call to the L2 techs. So give a call to HP Tech Support and they will take care of this one way or the other.
Jun 03, 2011 | HP Office Equipment & Supplies
HP Photosmart All in One error message Ink System failure -Oxc18a0001
There are N no of steps to be done so i am pasting the HP URL ,please follow it and u will get to some kind of solution in the end or u might have to replace the print head .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3560280
All the Best
Feb 17, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP 8250 Photosmart printer that displays "system ink failure"
Try changing the ink cartridges.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Dec 31, 2009 | HP - HP Photosmart 8250 printer
Can't print on Photosmart 3110 all in one
This is a result in a print head failure or the use of non HP ink ether or there right you need to service the unit part will be needed if the maintance does fail. If your using non HP ink stop its use and purchase HP ink you be glad you did!
Nov 17, 2009 | HP Photosmart 3310 Printer
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
HP Photosmart C6280 Printer Logo
1,000 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
