Question about Simplicity SE3 Computerized Sewing Machine
My machine is constantley eating fabric, I had it worked on and it still jams and eats fabric.
    Genius:
  • 1,788 Answers
I would take it back to where I bought it and ask them to show me how to stop this problem. It looks like an expensive machine. If, that is not possible, try putting some decent weight not sheer tear away stabilizer, I have even used printer paper underneath the hoop. Also, check your bobbin, do you have a plastic one? I used to have a machine that jammed all of the time until I was able to get a metal bobbin and no more problem. You can take one of your bobbins into a sewing center and see if they can match you up with one of the metal styles. Good luck
Posted on Jan 03, 2011
Why does my 680 ex eat the fabric at the start of a seam? Have learnt to start about 4 stiches in, but feels wrong?
Be sure to hold on to the threads at the beginning of your seam. I use an anchor swatch to sew onto at the end of each seam. This is easier to hold onto, and it saves thread as well.
Jun 03, 2018 | Sewing Machines
My upper thread keeps getting rapped in the bottom of machine . It eats my fabric. What can I do
The most common reason for this is that the needle has been inserted backwards, always have the flat side of the needle inserted facing away from you and the rounded side of the needle facing you. If this is not the reason please comment with the make and model of your machine.
Mar 02, 2017 | Sewing Machines
My singer 6180 feet dogs eats fabric at the top of feed dogs fabric gets stuck and does not feed the fabric why???
It sounds like the height of your feed dogs is the problem. I don't know which model you have, but of it's a plastic casing, you will need to take it in for service.
Mar 05, 2015 | Singer Sewing Machines
Singer 5830c bobbin issue, my machine tends to eat the back right prong of the bobbin holder, I've been through way too many of them. Before hand it sounds like it's jumping around in its place, and the...
Are you using a quality thread (top and bobbin) and is the bobbin a genuine bobbin?
Change needle regularly - do not use blunt or recycled needles. Correct needle for type of fabric
Oct 14, 2013 | Singer 2263 Mechanical Sewing Machine
My machine is eating fabric and jerking upper thread
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the thread has not come off the thread take up lever--that can
cause problems
here's a link for a free manual
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Sep 27, 2012 | Singer Inspiration 4210 Mechanical Sewing...
How do you prevent pfaff sewing machines from eating up the fabric at the begin of every seam? do you have to start in an 1/8 inch each time you start a seam, or can you start a seam right at the edge of...
This happens with other brands as well.
Hold on to the threads behind the presser foot and hand walk the first two or three stitches.
Some like to use a leader/spider.
Fold a scrap and stitch to the edge and then **** with the fabric you want to sew.
Remove the leader and use over and over and soon the leader threads will resemble a "spider".
Mar 09, 2010 | PfaFF Sewing Machines
My brother sewing machine jams threads under the needle and will not go, all the thread has to be pulled out gently as not to break the machine. It will not sew at all now.
hi there, why is it that i can't sew at all..both thread are not working instead eating each other thread under....but i have a good brother ls 2125. ty...
Mar 08, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Dec 03, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
My sewing machine makes globs of thread on the underside of the fabric
This happens to me when the machine is not threaded correctly, make sureyour machine is threaded right, then adjust tension if it still happens.
Mar 15, 2008 | Kenmore 15358
Simplicity SE3 Computerized Sewing Machine Logo
50 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
