Question about KitchenAid KGYS850LT Gas Dryer
KitcheAid dryer KGH801PMT1 is not heating up?
  • KitchenAid Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
DRYER WON'T HEAT
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Not-Enough-Heat/
When your gas or electric dryer is not producing any heat or not enough heat to ... If the sensor is defective, either the igniter won't glow or the gas valve won't ...‎How to test a dryer's heating ... - ‎How to open your dryer's cabinet
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
How To Troubleshoot A Dryer That Won't Heat ' PartSelect.com ... If you're using an electric dryer check ...
Oct 30, 2015 | Dryers
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
KITCHEAID K5SS NO SOUND, DOESNT TURN ON
Could be a variety of issues. There is a circuit breaker located in the top section I believe, but I am thinking it is a thermal breaker. It is possible the brushes have worn out on the motor if it has seen a lot of use.
Apr 12, 2013 | KitchenAid 32685 Mixer
CLEAN LIGHT BLINKS 7 TIMES ON KITCHEAID KUDP DISH WASHER
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Aug 08, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Think ignitor has gone on my kitcheaid gas dryer, model kgys700jq1. the problem is i dont know how to get to ignitor!
Hello Woodpizza65,
To disassamble the dryer to get to the ignotor,open the lint filter door,you will see two phillips head screws there,remove those ,then use a flatblade screwdriver and place it between the top and front panel and gently push the screwdriver down, the top will pop up so is can be raised upward(its hinged so no worry about it falling off) in the upper corners of where the front panel attaches to the other cabinet,usea 5/16" nutdriver or socket to remove those and then the front panel can be pulled out then up (note the green colored clips in the lower part of the front cabinet and the corosponding slots in the front panel they must interlock when reassambling the dryer) with the front panel off the burner asm. will be on the lower left side of the base frame, use a 1/4: socket or nutdriver to remover the screw holding in the ignitor out..replace ignitor and reassamble
ps before i forget once the top is raised before romoving front panel usea small flatblade screwdriver placed on the plug for the door switch(right side top) pry slightly and the plug will come apart so the front panel can be moved away
also when reassambling usea second person to hold drum up in the rear of it so its easy to reinstall the front panel since the drum will droop down
Jul 23, 2011 | Dryers
Kitcheaid KUDM24Se is no longer cleaning dishes. I looked for a way to clean filter but didn't see one. Coarse baffle at filter has lots of junk under it. Owners manual says this is not removable. ...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 05, 2011 | KitchenAid KUDM24SE Built-in Dishwasher
Cleaned now wont turn on? power clock flashing
sounds like you have a built in kitcheaid oven? usually blows the safety fuse in the back of the oven. it's proper name is thermal cutoff. need a model number for the part you need
Aug 30, 2010 | Ovens
Gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Sep 16, 2009 | KitchenAid KGYS750LQ Gas Dryer
Water leak
A number of fridges deal with condensate by feeding it down to a tray on top of the motor where it evaporates due to the heat from the motor , by pulling the fridge out you should be able to see if this is the case , if so has your tray rusted away and is leaking straight to the floor
Or
The insulation on the fridge shell may have broken down causing ice to form between the outer shell the filler and the inner lining.
This will condensate and will run down onto the floor.
May 25, 2009 | KitchenAid Refrigerators
Kitcheaid topload washer - hot water comes into machine but cold
check your hoses you might have them reversed.
Jan 01, 2009 | Washing Machines
KitchenAid KGYS850LT Gas Dryer Logo
67 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
