Question about Indesit Dishwashers
New integrated Indesit DIF16 dishwasher starts to beep minutes after starting a cycle and doesn't get as far as washing anything. I've not used it yet as I'm trying to complete the initial wash before fully using it.
markevans
  • 148 Answers
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
yalmer
  • 552 Answers
SOURCE: Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Posted on Mar 21, 2008
SOURCE: Dishwasher not resetting before new cycle
I have had the same problem. The issue is with the dip tray + overflow detector under the machine. What happened is the dip tray is full of water and the overflow detects this condition and prevents the machine from starting.
It looks like there is no water present in the machine but the drip tray, located underneath, is full. Give the machine a good shake and you should see water.
I solved it easily: just get a mop, lift the machine's front so that it tilts backwards and collect the water as it escapes the drip tray towards the back of the machine. The tray can collect quite a bit of water so you're likely to need a few tilts until it's empty.
In my case, the underlying case had been a previous mistake - we didn't allow the machine to finish completely and water had remained on it. Somehow the water had found its way to the tray. Other causes my be another appliance sharing the same waste pipe and pushing water down the dishwasher's waste system.
Posted on Nov 12, 2008
SOURCE: Tecnik dishwasher keeps on washing... and washing!
the "programer" has gone
Posted on Dec 11, 2008
SOURCE: Dishwasher beep twice but dont start washing
Replace door switch
Posted on Jan 01, 2009
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher filling up then stopping
is it going into the wash or just filling and thats it? if it fills and does nothing straight after it is probably the wash motor is jammed or seized. if the d/w starts to wash then stops it may be the heater is faulty.
Feb 16, 2008 | Indesit 24 in. DI67 Free-standing...
Indesit D61 Dishwasher element fault?
poss element or heater relay on the pcb.
Jan 19, 2008 | Indesit 24 in. D61 Free-standing...
Indesit D41 Slimline
HI THERE - I ALSO INHERITED A D41 - I HAVE JUST FOUND - SITE WHERE YOU CAN DOWN LOAD INSTRUCTION MANUAL FOR MANY INDESIT PRODUCTS - I NOW HAVE INSTRUCTION MANUAL FOR MY D41 NICELY PRINTED OUT - SEE www.indesitservice.co.uk hope this helps you too - Helen
Nov 14, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
151 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
