Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My hotpoint aquarius wdl540 keeps tripping the switch on the main fuse for the kitchen plug sockets
  • Hotpoint Master
  • 1,527 Answers
Hello, the reason for this because theres a dead short inside washer or the socket may have a loose wire check all the earth wires inside the washer and the sockets get back to me if you still have trouble
regards
shaun
Posted on Jan 03, 2011
  • jamesdanielg Jan 05, 2011
    thanks i'll try this
what turned out to be the problem as Im having the same problem?
Posted on Nov 25, 2011
  • shaun taylor Nov 25, 2011
    it could be a bra wire touching the metal part of the washer causing it to short out
Hotpoint aquarius wdl540
if the washer has water in, disconnect the waste hose and put it in a bucket and drain out manually, once the water level is low enough the door lock should release without the appliance being plugged in
Apr 04, 2014 | Washing Machines
Instruction manual for hotpoint aquarius WDL540 7kg Washer/dryer
My washing machine's indicator flashing after 5 minutes,what should i do?
May 13, 2012 | Washing Machines
Hotpoint aquariu 900 keeps tripping electric. I have changed fuse in plug but it still trips
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. We would need to know exactly at what point in the programs it does it ;-0(
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Also as a help for the future there is no need to change a fuse if it hasn't blown ;-0)
Sorry again and good luck,
John C
Mar 19, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42. I was using the machine when there was a bang and the electrics tripped. I reset the fuse box, checked the plug fuse and the socket but still nothing. No lights so presumably no...
It more than likely is the motor that has shorted. Remove lower rear panel, remove belt. Undo 2 screws that hold motor in place, remove motor plug, lever motor back to remove same,
Remove carbons and check for wear, also look at armature and see if there is any sign of shorting, clean armature with emery paper, fit new carbons, refit motor and belt, test.
If it still does not work, then in all probability it will have blown the main control board.which would require replacing.
Dec 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Oct 16, 2007 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
734 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
