When I press the on burtton it displays E003 and then shuts off.
  • hpb2 Jan 05, 2011
    This is for a office copier not a FAX machine !
    The copier is a Canon PC 850.
The E003 error code is a heater temperature problem (abnormal drop; low-temperature detection)
The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty. To clear the error, execute the following in service mode:COPIER>FUNCTION>CLEAR>ERR
Posted on Jan 05, 2011
  • 17,970 Answers
This would be a fuser error code; low temperature error in fixing temperature control. I suggest check and clean the thermistors, thermo-fuses and the heater lamp.
If this dont work, change the fuser unit if its due or close to its life expectancy. Power supply for power related issue. Most likey its going to be a the heater on the fixing flim assembly.
Keep us update.
Posted on Jan 04, 2011
  • ZJ Limited
    ZJ Limited Jan 05, 2011
    The error code E00 is a memory threshold error what it means is your
    machine has logged 4 of the following errors, E001,E002, or E003. It is a
    lockout error and the machine cannot be used untill the problem has
    been repaired or the errors cleared.
    E000, E001, E002, E003 CODES
    To reset these codes perform the following:
    - Remove the front panel and be careful not to bend or break the flexible cable connected to the panel and the DC Controller.
    - Turn on the copier and short the jumper wires JP3 and JP4 on the dc controller pcb with a screwdriver.
    - The count ratio indicator on the control panel turns on 'F'. When 'F' is turned on stop shorting the jumper wires
    - Turn off copier and turn it back on and its then reset.
    Send us news.
  • ZJ Limited
    E003 usually main thermistor on fuser roller. Try gently cleaning face
    of thermistor; don,t reset more than once in 15 min. or you may cause
    overheating and melt parts you don't want to.
Error code E000003-0002 canon irc 2880i
you can=
Clear the error code in service mode
but I would inspect the following first !!!!!!!!!!!!!!!SERVICE MODE
press Additional Functions Key (once)
press #2 & 8 key at the same time (release both)
then press Additional Functions Key again (release it)COPIER>FUNCTION>CLEARERR Clears error codes.
(Cleared error codes: E000, E001, E002, E003)
Operation method
1) Select this item, and press the OK key.
2) Turn the main power OFF/ON
E003 with a sub code of 0002, which indicates that the machine detected an abnormally low temperature when the fixing heater is turned on.
Check the temperature in service mode and see if the readings for the sub thermistors under Display for FIX-E and FIX-E2 would bounce back an forth between 0 and 36 degrees repeatedly.
1-Faulty Fixing Film Unit
2-DC Controller and DC Driver
NOTE:
Before replacing such things as, the entire Fixing unit, the DC Driver PCB, AC Driver PCB, and DCON; check SW3 and it's right door actuator.
In some cases SW3 has been found to also cause E003-0002 codes (also sub code 0000).
SW3 is the Fixing unit's AC interlock switch. Sometimes the right door actuator will be bent and not fully press SW3 when the right door is closed. SW3 is a button switch located right above some of the Fixing unit's rear frame connections.
SW3 has been found to show signs of wear and have carbon build up inside it. If the right door actuator is straight and making good contact , inspect SW3 and it's AC connections. If any flaws are found after inspecting SW3, replace it. SW3's part number is, FM2-9427-000.
The image below is for reference purposes only, it points out SW3 and it's right door actuator.
Oct 17, 2016 | Canon Office Equipment & Supplies
How can repair an error of canon 2202 E000-0000 error code?
The E000, E001, E002, E003 and E007 are temperature error codes. Fixing these errors are necessory part of every
photocopier and printer. It is usefull to apply high temp and pressure to melt toner into the fibers. follow these steps
to reset E000, E001, E003 and E007.
Enter into service mode by clicking on key "2" and "8" the SSSW will display
Change bit switch 1 to bit 0
Press OK
http://canonprintersupport.us/
Sep 05, 2016 | Canon Office Equipment & Supplies
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
How to reset IR2020I
May 09, 2014 | Canon iR 2020i Laser Printer
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Title : E003-0000 is displayed upon recovery from sleep mode
Error :
Workaround :
When a machine is in sleep mode and is recovered an error code "E003-0000" was displayed.
It is caused during the fixing temperature control at recovery from sleep mode, electrical noise affected the thermistor.
In order to increase the length of time for idle rotation of the drum (by 30 sec) at start-up and prevent electrical noise from affecting the thermistor, make the following selection:
Service mode (Level 2)> COPIER> OPTION> BODY> DRM-IDL = change the setting to '3'
Note: The length of time for idle rotation is being increased by 30 sec.
This mode will delay start of the machine by 30 sec.
or
Product : imageRUNNER 7086 imageRUNNER 7095 imageRUNNER 7105
Title : E003
Error :
E003-0000 Error Code can be displayed when the reading of the main thermistor is below 70 deg. C for 2 sec. after it has exceeded 100 deg. C.
Workaround :
1. Although the fixing heater or the temperature-detecting thermistor may be faulty, before replacing these parts, check J508 on the DC controller PCB for poor contact and refit it if necessary.
2. Make the following selections to clear the error code: [Service mode > COPIER > Function > CLEAR > ERR > OK]
Jul 18, 2013 | Canon imageRUNNER 5000 Copier
When I switch on the copier , it displays massage "E003 please press switch off then back to switch on.
it is related to your fixing unit. check your fing unit and power(electricity) also.
Apr 26, 2011 | Canon NP 6050 Copier
Canon iR2200 Copier
E003 is a fixing unit error code. Have you been having power problems? Is this the first time it showed up? If so you need to reset the code in service mode..
Resetting Code: Press "*" additional fun.
Then at the same time "2&8" Then the "*", then touch "Copier", "Funca", "CLR", "ERA", then "OK"... then turn the main power off then on.
Jul 10, 2008 | Office Equipment & Supplies
jasbo
jasbo
