How do i tell the amps for a t4ah 250v ceramic fuse? and is there a substitute for it? it came out of a microwave oven behind the panel.
    Brigadier General:
  • 8,909 Answers
That is a Time delay 4Amp High break rated 250Volt Sand filled Ceramic Fuse link
Hope that explains it for you. If you aquire a new fuse it must be Time delay 4Amp Ceramic type otherwise it could be a hazard.
Posted on Jan 03, 2011
Replace a fuse on GE Profile model jvm1871SH02
Unplug microwave or shut off house breaker. Remove grill or cover that goes across the top of door and control panel.Remove screw that holds control panel on and lift up on control panel. It will tilt downward and has 2 tabs at the bottom that go into slots. It can be lifted out of those slots.The fuse should be seen at the top area in the microwave behind where the control panel was mounted. Fuse is usually small 1/4 round type fuse like old type car fuses that were glass but the micro fuse will be either a white of gray ceramic fuse not glass. Some are 15 amp some are 20 amp. Usually stamped on end of fuse.
Mar 01, 2015 | GE Microwave Ovens
Ceramic fuse blows on power board
the power board is shorted and will need replacement. Yo can get the power supply board from www.tvrepairworld.com
Mar 16, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
Have power but the microwave won't turn on but the timer counts down the time and have power and lights still work.r-1502
on the inside panel or bottom panel there is a fuse in there once you pull the panel you will see it, it is more than surly burned out and needs a new one thats all, but the company dont tell you that because you wont buy aother if you can fix the one you have ffor less than a buck
Apr 08, 2010 | Sharp R-1502 Microwave Oven
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Fuse is blown
It's 20mm !!
It will have failed for a reason.
At 15amps, I'm guessing your Microwave has a grill too.
It could just be a bulb failure causing the fuse to blow.
Replace it and try again.
If the oven works but no light, that was the cause.
Apr 26, 2009 | Microwave Ovens
I got a Galanz microwave Moldel # P60D17L-D5 and cannot find a ceramic fuse anywhere it's 3/4 inch long and 1/8 inch diameter. I've tried emailing the company but no reply's.Anybody got any idea's
The microwave oven use a slow-blow fuse. If you look on the around the end of the fuse, you will be able to tell what size it is. Example (250v 3Amp) Your fuse may be found at Hardware stores in the electrical isle or a Radio Shack. If you found my suggestions to be helpful, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Where's the fuse?
Yup, I had the same problem. The unit just stopped working. I gather that this is a common problem with this model. I followed other posts elsewhere, and found the fuse behind and near the top of the control panel. There's a white, cylindrical plastic thing about 1.5-in long in one of the wires that run down from the main fuse in the upper right corner. Pop open the case (you may have to cut a plastic tie around it). I replaced the fuse. My microwave is working now. We'll see how long it lasts.
It's hard to tell what kind of fuse it is, but reading elsewhere, it's a 250V 4A 5x20mm slow-blow fuse.  I haven't found a ceramic one just like came out, but a 4-pack of glass fuses that fit the specs are $3 at Radio Shack. PN 270-1066. (No endorsement implied, it's just where I found something that worked.)
No, the fuse in question (and there appears to be another like it lower behind the control panel) isn't on any of the diagrams or parts lists.
Jan 10, 2009 | Whirlpool MH3184XP Microwave Oven
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
Televison & Video Logo
938 people viewed this question
Top Televison & Video Experts
Electro Med Services...
