Question about AOpen XC Cube EZ65 Barebone
Constant beeping while attempting to boot up
Computer will not boot up, Just makes loud beeping when power is turned on.
  • kpdigital Jul 11, 2008
    To elaborate..
    The system starts with full fan, then begins a continous monotone beep. The beep last for several seconds and then stops. After a few seconds begin a series of tones that sounds very much like an old modem.
    What is going on?
    Thank you.
  • kpdigital May 29, 2009
    IT was the ram. Thank you.
    Scholar:
  • 99 Answers
There is probably an issue with the RAM. Take the RAM out and put it back in see if that fixes it. If not then take it out and if you have 2 sticks of RAM put only one in at a time to see if the computer will boot on either stick. If that still does not work then most likely either all of your RAM is bad or there is a problem with the motherboard.
Posted on Jan 04, 2009
My computer has a RAMDDR2 but would not start up,can u help me diagnose and troubleshoot?
First make sure you haven't installed too much memory. The computer uses DDR 2 memory but what is the maximum amount it can use. If it can only support 2mb and you have 4 installed the computer will read that as an error during boot up. Second, disconnect the Keyboard and as the computer is booting access the BIOS. disable the stop on all errors setting so it can get past not sensing the keyboard and see if that boots. If the computer boots after that the problem is a fault in your keyboard like a stuck key which will give you the constant beep. If you see the spalsh or BIOS screens then the problem is not the Video Card. If you don't get those screens double check and make sure the Video card is properly installed with nothing installed in a slot directly below it as this sometimes causes conflicts.
Nov 17, 2011 | EliteGroup P4M800-M7 Motherboard
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
I have a Presario SR1950NX that is not booting. After turning on power, the fans come on and the DVD drive flickers, then nothing else happens. The keyboard and maonitor stay dormant. Normally, a loud fan...
It may be the clogged fan that caused this problem then resulted to overheat. possibly you need to replace the motherboard. or first, try using a bootable cd to boot your pc up. it may also be an issue with your hard drive not booting up.
Mar 29, 2010 | HP Compaq Presario SR1950NX PC Desktop
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
Loud ring while trying to boot for first time with Asus P5Q3
Hi im josh in cebu phils. may i help you. i got the same problem last week when i bought intel board. the same problem you have a long loud beep in the first boot. it is a video card problem.if you are using video card having 128 mb or below it will beep and may damage the motherboard. but when it is higher 128 like 256 or 512 mb it is good. i solved this problem of mine. i hope the same you too. Good luck
Feb 15, 2009 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Dell Poweredge 700 Server problems
Dear jckim, Which server you are using? Usually this error occurs when raid controller card have some problem.Have you getting any error codes?
Oct 20, 2008 | Dell Computers & Internet
Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
Jul 11, 2008 | AOpen XC Cube EZ65 Barebone
Starting computer
Your power and data system need inspection inside the MoBo. Hardware problems produce warning beeps, especially RAM and VIDEO. Check these first to make sure they are in slots.
Does it show anything on the screen while it's beeping??????
Please provide more information and come back
Feb 19, 2008 | MSI K8N Neo4-F Motherboard
AOpen XC Cube EZ65 Barebone Logo
277 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
