Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
The heater fan runs for about 5 seconds , does not heat and than turns off.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
This could be several problems. Check your fuel first. If it is old fuel from last year, get rid of it and fill with fresh. If it has water in the tank, your spraying water to your ignition source. If you have fresh fuel, it could be a fuel filter stopped up or your air pump is not set properly. Also check your ignitor to see if it is working properly. Some have a spark plug and some have a glow type ignitor.
Posted on Jan 03, 2011
Why does radiator fan work when air is on but not when heater is on?
Have you waited long enough?
Sometimes it can take 5 -10 minutes before it turns on while using heater.
Oct 22, 2015 | Toyota RAV4 Cars & Trucks
Why is this Pool heater making a very loud whistle sound after heater is fired up.
sounds like a leak in the air stack or if coming from gas valve need new gas valve
Aug 28, 2014 | Sta Rite Pool & Spa
I have had a Reiker Heat/ cool fan for 3 years and have had no problems, till now. All parts are working ,lights , fan, remote, but I have no heat. How do I fix this. K.
I had the same problem and fixed it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat using the remote. Then, leaving the remote turned on, turn off the fan at the wall switch or circuit breaker. Wait a few minutes and turn the electricity back on. Then, within 30 seconds, and within range of the fan, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat began working again.
Jan 07, 2011 | Reiker RRC1200001 Heater
My new rieker fan stopped blowing heat- the fan works --not the heater
I had the same problem with my fan and solved it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat, even though the heat doesn't work. Then, leaving the remote on, turn off the fan at the wall switch (or circuit breaker box). Wait a few minutes. Then turn on the power and within 30 seconds, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat started working again.
Jan 05, 2011 | Reiker Ceiling Fan/Heater Combo Utility
How do you turn on the heater?
Mine has two switches one says cool - off - heat, the other says fan on - fan auto. For heat I set the first to heat and the second to auto. This puts everything in to heat mode and the fan runs from the furnace control now not constantly. Hope this helps you out.
Dec 28, 2010 | Honeywell TH4210D1005 Heater
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Heating & Cooling Logo
141 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
