Question about Audiovox - AS-9903 - Six Tone Car Alarm Siren, 120db 20 Watt
Audiovox AS-9903 Car Alarm - Horn Stopped working and key fob will not unlock the doors. the dash light indicateds that the alarm itself is working but the horn does not blow. the trunk will open and the auto start function still works. i removed the horn to find what could be wrong - is there someway to fix the horn or do i just need to get a replacement? hate to buy a new horn if it isn't necessary - sooo before i go tearing into the horn i thought i would check with you guys for suggestions. also what would cause the doors not to unlock with the fob since other functions work -
5 Suggested Answers
jpk528
  • 95 Answers
SOURCE: 94 crown vic remote start??
you will not need anything else. If your not planning on doing it yourself than you will need to bring it to a shop to have it put in. This car is pretty system install. You can obtain a wiring diagram for it and put it in yourself. But if not you will not need anything else for this vehicle
Posted on Feb 20, 2009
MECP Guy
  • 344 Answers
SOURCE: starter button did not work and when use key to
something is not hooked up properly with the remote starter, it sounds to me like the unlock wire on the remote is hooked to the factory arm wire on the alarm
Posted on Jan 16, 2010
  • 50 Answers
SOURCE: camry 1995 AS-9903 Alarm Problem
LOOK FOR A TOGGLE SWITCH IN DRIVERS KICK PANEL. ONCE FOUND TURN KEY ON THEN FLIP SWITCH.
IF ITS A PUSH BUTTON SWITCH THEN TURN KEY ON AND THEN HOLD THE BLACK VALET SWITCH DOWN FOR 8-10 SECONDS.
DONT LET MORE THEN 5 SECONDS GO BUY BETWEEN STEPS.
Posted on Jan 22, 2010
sonicboomele
  • 1557 Answers
SOURCE: i cant get my car started because of a kill switch
there must be a key switch on the pezo have it bypassed its the only quick cheap way if its not on the side of the pizo ( siren then its inside the pizo
Posted on Dec 31, 2010
Horn goes off when I connected jumps leads to range rover sport 2006. I couldn't get into car as remote fobs wouldn't unlock or lock car I manage to get by using the key and doing the 151 sequence which I...
That's usually what happens when the battery has gone dead and when you are reviving it by hooking up another battery the horn goes off because it is hooked up through the car alarm. Try dissarming the alarm after you hookup the jump leads. That should work.
Mar 12, 2014 | Cars & Trucks
Car alarm goes off when unlocking door
You will needs to think of it this way. Once you set your alarm it is looking for the corresponding signal to disable itself. That comes from the fob. If you don't use the fob and just use the key, the alarm system is doing its job and alerting you since it has not received the disable command from the fob. Either lock the door with the button when you exit the car if you want to use the key or use the alarm fob. This will also happen if you use the car manufacturers fob to unlock the car if you have locked it with the alarm manufacturers fob.
Hope that helps - I have hidden all of my original car fobs to help alleviate this problem!
Dec 29, 2013 | Cars & Trucks
My audiovox car alarm is WAY too sensitive and I am wondering if there is a way to
There should be a screw like knob usually installed underneath the dash that allows you to adjust the sensitivity of the alarm. Start there. You should find what you are looking for.
Jul 04, 2012 | Audiovox - AS-9903 - Six Tone Car Alarm...
Central locking has stopped working properly and I can not open any door other than the drivers door and that is with the key. This has been like this since the alarm went off on its own and would not...
The alarm will time out and turn itself off after a minute or two when it is tripped. This turns off the alarm, not just the alarm horn.
Are you saying that you can't unlock a door from the inside by hand?
Jan 04, 2011 | 2001 Volkswagen Jetta TDI
Everytime I lock the car using the key fob, about 30 seconds later the alarm sounds but the lights do not flash and the horn does not sound. Only when I unlock the car will it go off. I have disconnected...
you may have a bad door switch, theres a switch on the drivers door lock, when door is unlocked with fob or key the switch is activeated to shut alarm down,the lock moves to hit switch with key or fob,so if the switch is bad it will not shut down alarm, i would start there,door panel has to be remove,then latch has to be remove to get to switch, then test with a meter see if it opens and closes the connection, hope this helps.
Dec 26, 2009 | 2000 Jaguar S-Type
Camry 1995 AS-9903 Alarm Problem
Nov 25, 2009 | Audiovox - AS-9903 - Six Tone Car Alarm...
Vw golf 1.6 petrol alarm system stopped working with key fob/run the battery down
You do not state year of car.This is for most golfs 98-06.
switch ignition on
insert key to be programmed into drivers door lock
lock vehicle manually
press lock or unlock button
wait at least 1second
press lock or unlock button again
vehicle horn sounds to indicate correct programming.
good luck,barry
Nov 07, 2009 | 2001 Volkswagen Golf
Kia Rio 1.5 diesel Factory alarm,car horn honking,side indicators flashing,unable to start the car. When I arm the car with the fob and unlock the door with the key then open the door the horn starts...
The fob is infamous for its battery life. It gets drained so quickly that there happens to be a little later when the fob is very close to the door lock, ignition & unnecessary triggers the alarm due to low reception as the battery of the fobs discharges very fast, depending on the model, which has a certain virtual sheild(STARTRECK type) which is triggered by the fobs strength of the signal(radi waves).
Why not try a new set of batteries for your fob?? .................................sodeep
Oct 25, 2009 | 2003 Kia Rio
Pt cruiser disable alarm
battery of car is zapped of energy...not sure if alarm system to blame, after driving it for a few minutes..clock and radio display lights turn off, horn can barely be heard...sometimes, motor shuts down completely. have had to put in 2 new batteries in just a matter of 2 months?...any idea what this may be?
Oct 06, 2009 | 2001 Chrysler PT Cruiser
Alarm won't beep when doors are locked with key fob
hold both the lock and unlock buttons for three seconds the horn will honk and the lights will flash!
Nov 16, 2008 | 2002 Nissan Altima
Audiovox - AS-9903 - Six Tone Car Alarm Siren, 120db 20 Watt Logo
186 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
andy148814
Level 1 Expert
Rocguy
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
