Question about Samsung Audio Players & Recorders
Samsung HT-HTX22 home cinema problems with playing mp3 cds-disc error
  • 3 Answers
SOURCE: Samsung Series 6 TV - cannot get TV to go through Home cinema speakes
Ok, the Audio can only be transfered to the HT if it is connected via something other than the HDMI, (the HDMI is just 1 way accept for the Anynet function (which is great with the 6 series. I have the LE52-A656))
The audio can be transfered via component cables but you will get the best out of your system using an optical cable. The main reason for optical is it ability to transfer 5.1. Only problem is the Samsung does not output 5.1!! bugger!! one you have connected it via the optical too. just set the HT to D-IN and you should be goo to go! :) There maybe something i have missed but Im at work at the mo but let me know how you get on :)
Posted on Jun 16, 2008
  • 151 Answers
SOURCE: how to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 26, 2008
  • 11 Answers
SOURCE: The door open by itself
This can be caused by the drive not closing properly. Usually caused by a slipping drive belt or a faulty micro switch.
If it is a slipping drive belt then the draw closes but the laser assembly does not get lifted into place. If the belt is slipping either replace it or try belt anti slip spray.
If the micro switch has failed then the draw closes but the micro switch doesn't tell the CPU that it has closed so it times out and opens again thinking it has failed to load the disk. If the micro switch has failed it either needs cleaning or replacing.
Alternatively you could just replace the whole draw mechanism however this is normally much more expensive. There are other possibilities such as a faulty micro controller causing this but the two above are by far the most likely.
Regards, Andrew
Regards,
Andrew
Posted on Sep 17, 2008
  • 10 Answers
SOURCE: durabrand home cinema ht 391 manual
I dont think your system support 5.1
Posted on Oct 14, 2008
SOURCE: have lost the remote for our home cinema system,
look under your big but maybe youl find it...
Posted on Jul 15, 2009
Want to make samsung ht-x20 home cinema multi regional. when entering code 84269 and enter the player then shuts down. Still not playing DVD. It still asks "check regional code". Ernst
hi there! turn on the hometheater then wait for the no disc display, press the stop botton, do not release until the unit turn off, you will see the initial word on the panel,then try to play your disc
Apr 08, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
My samsung HT TQ22 dvd player doesn't play dvd's."DISC ERROR" appears each time I try to watch a movie. Any info on how to fix this problem would be greatly appreciated.
Take the top case off the unit, power on, and place a dvd into disc tray. Press the play button and see what happens. It should find the dvd, clamp it in the reader and then spin it at high speed. If it does this and still says disc error, then the read head is bad. If it does not spin at high speed, then the epindle motor is bad. This is the more common error with Samsungs. Repair shop time.
Mar 09, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung Home cinema HT-TXQ120 system won't read CDs and DVDs.
Hi.
I have had the same problem.
Just unplug the systme and plug it back in.
Jan 03, 2010 | Samsung HTP-1200 System
I have a sumsung dvd home cinema system ht.thx25 when I put a dvd in it says disc unknown but when I put a free dvd in from the newspaper it plays.
Is the disc just a regular disc, not HD or blu ray?
Is the disc a region 1 coded disc?
If it is, the unit should play it fine.
Jul 01, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Apr 11, 2009 | Samsung HT-Z310T Theater System
No Disc display
wrong reganal code most likely there are sites were you can unlock your dvd player (hack it) so it will play disks from anyware
Feb 17, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
64 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
