Question about Compaq (162857-001) Motherboard
The software crash and I dont have the accompany disk. I formatted the system and LAN and system board not available.
Comapq 510 crashes in win 7
carefuully and quckly wach you compuer when it boots and press the right f something key i have a hard tiem doing this too there less then a 2 second window
its gonna say a coupla options befor it acutaly starts loading the win 7, so you gotta be on your toes,
i dont dont remember what 7 says cause me and my 7 have how shall it aherm eparted im back on good ol xp
so any ways it's imperitive that you press the on that getts you to bios
normall you you just dont mess with bios but sometimes you simply must now is one of those times alls you ahve to do is put the lan wifi switch on in bios and violins you is up and runnin on the internets in no time fliat
bye bye
michet@aol,com
Jun 15, 2013 | Compaq DECbridge 510 (defebad)
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
How can I recover files after my computer crashed?
Hi i recommend you to try Recoverfix for windows data recovery software. By using this tool you can easily recover your crashed files. The software free demo is available you can download it from here: http://www.recoveryfix.com/recover-windows-data.html
Hope it will helps
Nov 02, 2012 | Compaq Computers & Internet
Mine is a Dimension 3000, which P4, 2GB RAM, I just restored to original setting and some point uninstalled Win search programme. But now systems crashes when I eject DVD. I dont know whether I need...
From the information describes, it seems that this is a software issue. I would suggest re-formatting the drive and to start with a fresh windows install..
Jul 29, 2011 | Dell Dimension 3000 PC Desktop
Is there any software for boot manager?, because i dont have a hard drive for re-installing my HP compaq nc6220?
Hi, You need a Windows operating system CD or system restore CD that come with the computer. You need to format the hard drive and install windows. After that is complete you need to install all the drivers in order the lan controller, audio, and display will work properly. Get back to us if this information helps you solve the problem.
Jul 13, 2011 | Computers & Internet
Re: R400 stuck at ThinkPad screen wont boot
Computers always boot from the hard drive.
The Bios on the mother board have a routine that tell it to boot from the Hard Drive, or USB in the BIOs setup.
to look at the BIOS setup, when you turn it on keep pressing the <ctrl><alt><del> keys on your key board, this should let you go into BIOs setup. there you can check which device it the first boot, second boot and third boot.
If your hard disk the boot, it is probably crashed, you will have to take it in to be repaired, and you might need a new hard disk.
in which case the repair shop will have to put in a new hard disk, format it as bootable, then reload the operating system, and any software you might have been using, so take into the shop all cd software disks with the computer to the shop so they can reload all your stuff. If there were any files you had on the disk, they may or maynot be recovered.
Good Luck...
Nov 11, 2010 | Lenovo ThinkPad R400 Notebook
I have failed to install ethernet driver after
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
Mar 01, 2010 | HP Compaq d530 SFF PC Desktop
Crashed hard disk
firstly you are delete the partion and then formate the harddisk of quick NTFS mathode .
and install the softwere of essy recover and choose the option of raw data recover .
shiv mishra
9654535008
Apr 08, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Compaq (162857-001) Motherboard Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
