Question about KitchenAid KERC607 Electric Kitchen Range
KitchenAid Oven YKERS807SS - just installed brand new, and the oven display is stuck on "Cavity Size". When you press "Start" to set it, it is showing an error. Any solution? There is nothing in the manual for setting the cavity size.
tony2155
  • 64 Answers
SOURCE: range has error of stuck key
need to replace touch pad not cheat
Posted on Jun 23, 2009
ginko
  • 19396 Answers
SOURCE: my oven door fell off.
You need to put door back in the hinges , pull it up and slide it back.
If door does not fit, you may need to have hinges replaced.
See diagram below , click on picture to enlarge:
Posted on Apr 07, 2009
SOURCE: My kitchenaid superba has the control lock stuck
the control lock shows up on my stove how do i get it off.
Posted on Aug 17, 2009
  • 17 Answers
SOURCE: I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Posted on Nov 14, 2009
  • 291 Answers
SOURCE: Kitchenaid Superba - oven stopped and code F2E1 is
F2 E1 is an error code that says the membrane (touch pad assembly) is not connecting to the ERC(Electronic Range Control). Call the warrantee company and give them the model number and serial number of your range and ask them if it still has a parts warrantee on the electronics. If it does, they will have to send their technician out to replace the part or parts and charge you for the labor. Your model may have the membrane and Erc all in one part, so an easy diagnosis, if it is seperate you need to make sure the membrane ribbon connector is plugged tightly into the Erc, plug your range back in, press cancel, and then retest. If it still fails then replace the membrane, test and if it fails again, replace the Erc. Before you tear into this make sure you unplug the unit for 30 minutes, plug it back in and test. Sometimes this will reset the Erc and solve your problem. If it doesn't the make sure you unplug the range before doing any repair work. Good Luck, Appliance Specialists
Posted on Jan 06, 2010
How do I turn off demo mode for KitchenAid Model KEBS179BSS00
The following is from your Users Manual:
Demo Mode IMPORTANT: This feature is intended for use on the sales floor with 120 V power connection and permits the control features to be demonstrated without heating elements or burners turning on. If this feature is activated, the oven will not work.
1. Press OPTIONS until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START to save the setting.
5. Press OFF to exit and display the time of day http://www.kitchenaid.com/digitalassets/KERS306BSS/Use%20and%20Care_EN.pdf
Feb 19, 2015 | KitchenAid Ovens
KitchenAid Gas Range Model KGRT: Oven temp won't go past 260 degrees. When a higher temp is typed into keypad, it gives me an "err" mesage.
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
Mar 27, 2011 | KitchenAid KGRT607 Gas Kitchen Range
How to resolve the F6 E0 error code on the built-in Kitchenaid microwave oven? The unit was brand new and installed 2 and half years ago in my new house. One website mentions the description for this...
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 26, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I recently install a new control panel & display board now f1 e3 displays in clock . Any ideas of reason why ?
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Oct 14, 2010 | KitchenAid KGRC707 Stainless Steel Gas...
Microwave oven was very hot and shut down with blank display.
For future reference, I always recommend that you turn on the microwave's hood vent exhaust fan whenever you're cooking on the stovetop or oven.
Depending on the brand and model, there will be either a thermal cutout or thermostat on or near the magnetron. There is also one on top of the oven chassis ceiling, but under the outer cover.
Either device may have opened.
In many brands there is a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat / thermal cutout) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jun 20, 2010 | Jenn-Air JMC8127DD Microwave Oven
Sharp R1211F microwave After shutting door and pressing start, loud buzzing and flash in oven
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can order parts for this brand from Encompass here or you can call them toll-free at 866-779-5835.
Oct 09, 2009 | Sharp Microwave Ovens
''Cavity Size 30'' message appeared, can't get rid, can't use oven
Had the same message on my display after spilling water on the cooktop. Obviously, the seal (rubber gasket) that prevents liquids getting inside the control area is not very good.
I replaced the Control (p/n: 10181439 / 9761799, 2 numbers, same part) and the flat cable between the touch keypad and the Control (9762781).
After turning the breaker back on, only had the message to set the clock.
Feb 23, 2009 | KitchenAid KERS807SSS Electric Kitchen...
Microwave is arcing. Can it be fixed?
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
For many brands, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you need further help, please please reply back with your brand and model number so we can help you.
Feb 14, 2009 | KitchenAid KEMC377K Convection / Microwave...
KitchenAid KERC607 Electric Kitchen Range Logo
208 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
