Question about Vizio VW42LF 42 in. LCD HDTV
I am not able to connect AV2 to my HDTV. I connected PS3 station to it. but now it says AV2 searching. i checked all the connections. its ok.
    Master:
  • 362 Answers
Ok so when you power on the ps3 hold the power till second beep and then wait ok
Posted on Jan 03, 2011
The av2 input doesnt work
Look for any loose contacts in RC jacks/sockets/Cable. Connect another input on that input of the TV and check. Connect your ps3 to some other TV and check.
Aug 05, 2012 | LG 32LG30 32 in. LCD HDTV
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont display on the tv!!
Jun 10, 2010 | Sony PlayStation 3 40GB System
When I try to connect a Wii console to my LG television, I put the connection in AV2. But then I get the message that there's no LG signal.
Using the yellow, white and red audio/video cables connect to the side panel of your LG TV and switch the Wii console on. Then press input button on remote and select AV 3 then OK and you should see Wii Menu.
Jan 04, 2010 | LG 37LH30 37 in. LCD HDTV
Trying to connect Playstation3 to my insignia 37". I connected the cable to the AV2 slots and switched tv to AV2 and still it says no signal.. what am i doing wrong?
Hello Yasman,
You might want to try a factory reset on your PS3 = turn it off then hold down the power button for 5 seconds it should then Beep.
There is a small memory in the PS3 that stores info about the tv that is was Initially setup on. IF you do this reset this should allow you to connect it to your Insignai tv Another Tip i would do is connect it all up with it turned off then power up your appliances once its all connected.
Hope this sorts it out for you
Little Dish Fitter
Oct 05, 2009 | Insignia LCDTV26 26 in. Television
WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Jul 08, 2008 | Philips WACS700 Shelf System
AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Nov 26, 2007 | LG 32LX3DC 32 in. LCD HDTV
Vizio VW42LF 42 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
