Question about HP J4680 Office Jet All-In-One Printer
It says that it has a paper jam but there is no paper jammed...need to reset it but don't know how
Check for stuck sensor actuator
Posted on Jan 03, 2011
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
13.02.00 paper jam on tray 2. i have removed the tray and even the catridges but can't find any paper. I don't know where the sensor is as this may be the cause as well. Please need urgent...
Number 1 you failed to mention what kind of printer you have.
Number 2 when you print, does paper even feed into the printer?
When was the last time that you replaced the feed rollers?
Yes it is possible that a sensor is jammed. Before the 13.02 error,
did the printer actually have a paper jam? If yes, was there a piece of paper
missing from the jammed sheet or was it whole?
Jul 15, 2011 | Office Equipment & Supplies
My fax machine (Samsung SCX4720F) is saying paper jam, there is no paper jam. I have taken out the paper and tryed cleaning the rollers and i'm still getting the error.
The problem is not in the rollers.
If you removed all paper and the paper jam error is still on, then the problem is with the paper sensor itself.
This might be reset by a service code (which I don't know) or the sensor may need replacing.
It is not a cheap machine, so you may want to spend some money servicing it.
May 11, 2011 | Office Equipment & Supplies
It is sying i have a paper jam but there is no paper in it
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
Dec 12, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper Jam light is on and there's no jam anywhere. What do you do?
A paper jam notification can be caused by two things. One a hard jam, paper stuck.
Two, If the paper does not reach a flag or sensor on time, the printer knows that a jam has occurred.
Most likely, you had a paper pick problem caused by dirty rollers or maybe the paper is held to tightly by the paper tray. Also a static charge on the paper can sometimes cause sheets of paper to stick together.
Don
Dec 09, 2009 | Dell 1720dn Laser Printer
Cleared paper jam but still have message
Mine does the same thing.Try opening all the doors on it and then closing it. For some reason the printer wants to know you have checked all the doors. Also take out the toner drum and check there. If that doesn't work try unplugging it and then plugging it back in. Good luck....hope it helps.
Jul 22, 2009 | Canon imageCLASS MF4370 Black and White...
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Please, i don t know to much about copier i have a canon ir 1600 when i powor it after sometime is displaying system error E000 sos please. zakaria
i dont know more abotu copier when the copier on the paper jam error wil displayed how to solve the problem the jam Error Code :0360-0-367596
Jan 06, 2009 | Canon imageRUNNER 2000 Copier
PIXMA MP450 alarm light is on and it says paper is jammed but there isnt any jammed, please help?
You could try this, but there is no guarantee. There are a lot of sensor in the paper path of a Canon printer. When these sensors get stuck in the up position, pushed up when paper is present, you get the paper jam alarm when no paper jam is present.
The trick to try that sometimes works is to run some index card stock through. Insert the index card stock in the paper tray, run a print test and as it runs put some gentle firm pressure on the card stock to ensure it travels smoothly. Once it is done the sensor may have reset itself. In lieu of card stock you can use a thick magazine cover and cut it to size of an 81/2 x 11 piece of paper.
If this works great. If it doesn't let me know and please don' t bother to rate this if it fails. It works some of the time and not most of the time.
Thanks,
Worldvet
Nov 20, 2008 | Canon Office Equipment & Supplies
HP J4680 Office Jet All-In-One Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
