Question about Whirlpool Duet GHW9150P Front Load Washer
Code F14 Our Duet washer is coming up with a code F14 can you tell me what to do about this? We did check the water hook up and everything is fine there.
Mine just had that error code and we found that the hose connection just inside the top cover where the water flows through to get to the dispenser was off. Because there was laundry on the floor, I did not notice that the floor was flooded from the water that was suppose to go into the machine. Hose came off, clamp was missing. TWO repairmen didn't seem to think it needed a clamp even through there are three other connections with clamps in the same area.
Posted on Jul 10, 2008
    Novelist:
    Champion:
  • 216 Answers
Greetings pattiprem,
This error message can sometimes be caused by a power glitch. Try unplugging the unit for 2 minutes to see if this fixes the error. Another cause can be a problem with your Central Control Unit.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on Jul 09, 2008
My machine shows an f11 or f14 error code and it won't work. What can I do?
Circuit Board Medics can rebuild and upgrade the CCU to eliminate the F11 error and prevent it from happening again. Find more details at http://circuitboardmedics.com/whirlpool-f11-code/
This video shows how to remove the CCU from the machine.
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer FH code "sometimes"
well..based on what you're stating here..sounds more like a sensor, based on the duty cycle.
Jun 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: what does the F14 error code mean?...
F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have went over checking the water lines and pressure and I even bought a new water inlet valve and the code fh is still coming on. I hooked it up just like the one that was in it. My washer is a...
The FH code means that the washer isn't detecting water at the flowmeter. Check the wiring from the flowmeter to the control board. There was a problem with this wiring harness jiggling loose and sometimes causing this problem. If that doesn't clear up the problem then I would consider checking the water level switch. Test it with a multimeter for continuity. A lack of continuity would indicate a faulty switch, perhaps stuck and telling the washer that the tub is already full and not allowing water flow to begin. Hope this helped and best wishes.
Aug 05, 2009 | Washing Machines
Whirlpool duet washer keeps flashing f14
"F14" is an EEPROM error on the Central Control Unit (CCU). The CCU is the main computer for the washer. This error is normally caused by a power glitch and can be cleared by unplugging the washer for 2 minutes. If the error code reappears, the CCU has to be replaced.
Jul 12, 2009 | Washing Machines
NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
239 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
