Question about LG Dryers
When my dryer gets down to 6 minutes...it doesn't continue to go down.... It just continues to dry and doesn't cut off.
    Problem Solver:
  • 16 Answers
Your timer is the culprit. Change the timer and enjoy the laundry. : )
Posted on Jan 03, 2011
It doesnt seem to dry very well or takes a really long time
Zannusi Dryer TDS383W element gets Hot (glows)then cuts out after few seconds then if I wait for couple minutes and reset the clock to any set time the element glows hot again until inbuilt thermostats 'click' again cutting out the element,this process is continuous with or without the lid and ducting in place.
Feb 14, 2014 | Zanussi TD4112W Electric Dryer
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
Hello, I have a Kenmore Dryer 90 series... We are in a Town house on and the Dryer is on the 2nd floor and the vent goes up vertical for about 12 ft with a 45 then to the roof... my dryer gives off heat...
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
More than likely it is the heating element.Remove the front lower panel.While the dryer is running look inside at the bottom,if the element is getting hot you will be able to see it.If the element is not hot,replace it.
May 13, 2011 | Dryers
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
My DLE2514W LG dryer keeps running with 6 Min. Left
There is a humidity sensor (Hence the words Sensor Dry) inside the machine which trips out when it sees a lack of moisture in the air going past it.
It is not adjustable without special equipment
That sensor has failed and will need replaceing
Jun 07, 2009 | LG DLE2514 Electric Dryer
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Dryers Logo
69 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
