Question about KitchenAid Refrigerators
Have a KitchenAid Refrigerator top, freezer bottom model KBRA22KLBL01. Refrigerator is barely chilling, not enough to preserve food and freezer does not work at all. All power, lights, fans, etc are fine. Seals are in great condition.
the dr
  • 447 Answers
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Posted on Dec 04, 2007
Master_Tech
  • 770 Answers
SOURCE: Refrigerator not cold enough
check the back wall of your freezer for a heavy frost build up rhis is an indication of a defrost problem also make sure the fan in the freezer is working
Posted on May 11, 2008
SOURCE: Refrigerator and freezer not getting cold enough
If the problem just gradually started happening, it's possibly the defrost cycle that's not working right. Fridge doesn't defrost, the cooling system ices up, and the cold air can no longer travel through the fridge.
You can tell that's the problem if you fully defrost the fridge (turn it off for a day), then start it up again. If it works OK for a while, then does the same thing after a few weeks that's what it is. Either way, you need a repair person to fix it, or you need to defrost it regularly, but then what do you do with your food while you do that???
Posted on Nov 17, 2008
  • 93 Answers
SOURCE: Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Posted on Mar 15, 2009
lojacksdad
  • 121 Answers
SOURCE: build in kitchenaid, freezer working but not freezing
sounds like you nave a freon shortage or a restriction
Posted on May 08, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Hi, I have a Whirpool fridge, model ED22TW that is suddenly no longer keeping things cold/frozen. Both the freezer and fridge gauges are turned to the max however my frozen foods are still defrosting...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Refrigerators
Kitchenaid side by side model #DS 110022-RN refrigerator. The refrigerator side not cooling, air flow through top vent almost non-existent. The freezer side is at 0 or below with a very strong blow. The...
Either you have a defrost problem blocking airflow to the fresh food section or you have a blockage in the vent. You're going to have to unplug the refrigerator look in the back of the freezer and see if there's ice build-up on the rear wall of the freezer. Try again with that model number I do not believe that is the correct model number it should have Mod: before the model number.
Appliance 911 Sea Breeze if your refrigerator has an additional cooling Zone in the fresh food compartment you may have a damper that is stuck open but I'm going to have to have the correct model number to help you
Jun 21, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid superba side by side top is too warm,
The defrost cycle is suppose to be automatic on this model. To see if you have a defrost problem take the lower container out of the freezer, and empty the bottom shelves enough to see the back panel inside the freezer. If there is a build up of frost on the panel or the slots in the lower back panel the automatic defrost is not functioning. The most likely suspect is the ADC or automatic defrost control. This control runs about $120.00 and is located in the console of the fresh food section (top).
If there is no frost check to see if the fan in the freezer is running. If the fan is not running you have a failure of the fan motor which is a little less expensive but a bit more challenging to replace, the shelves, the shelf slides and back panel of the freezer have to come out to replace this motor.
Apr 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer on top model. freezer works fine. Refg. isn't cold. light works. frig. isn't room temp so SOME cool air is getting in - not enough to preserve food.
The duct that allows the air to the bottom has frozen over. Put remaining food in an ice chest and unplug the unit for about six to eight hours. This will allow the ice to clear and restore airflow. If you want to hurry the process then you can use a hair dryer and blow it through the opening in the rear top of the refrigerator. Hope this helps. Good luck.
Mar 06, 2010 | Kenmore Refrigerators
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Top is not cooling, sn no cold air is coming into top. Freezer seems to be working
SOUNDS LIKE THE CIRCULATING FAN IS WEARING OUT. THIS PROBLEM IS VERY HARD TO DIAGNOSE BECAUSE THE FAN SPINS BUT NOT FAST ENOUGH TO CIRCULATE CHILLED AIR THRU THE FREEZER AND REFRIGERATOR. THE MINIMUM COST FOR PARTS AND LABOR IS AROUND $300.00. THE FAN IS LOCATED BEHIND THE BACK PANEL OF THE FREEZER COMPARTMENT.
Aug 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
My kenmore bottom freezer refrigerator keeps icing up how do i defrost it? model # 596.7182101
Sounds like the circulating fan is wearing out, this problem is very hard to diagnose because the fan still spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost for labor and material is around $300.00
Aug 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Jenn Air bottom freezer refrigerator is too warm in the fresh food (upper) compartment. This just occurred today. The freezer works fine. Any ideas?
sounds like the FF(Freezer Fan) is starting to wear out. This fan problem is very hard to diagnose because the fan will still spin but not fast enough to circulate chilled air thru the freezer as well as the refrigerator.
Jul 30, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
