Question about Craftsman 20 hp 42 in. Deck Yard Tractor
It will not start there is no spark. It is a 2001, 20ph. and do you know how much the parts will be to fix it? Thanks for your help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
I tried to e-mail you before but I had not sighned in by mistake. I had given a solution about oil level; however on seeing the part where is no spark, I suspect it could be a problem with the distributor or magneto if you have no spark. Clean all electrical contacts starting with the battery posts and work you way up to the spark plug(s).
ASH
Posted on Jan 03, 2011
Does not start
Start with the basics ... take out the spark plug, attach the plug wire to it and hold the metal part of the plug to the a metal part on the engine and turn the motor over like you would when trying to start it ... look if the spark plug is sparking. If yes next thing ...plug the plug hole with your finger while turning it over and the compression should push your finger away from the hole. If yes, put the plug back in and hook it up. Spray some quick start of carb cleaner into the intake or carburetor and try to start it. If it runs briefly you have a dirty carb or no fuel coming to it.
Hope this helps.
Sam
Oct 22, 2017 | Cars & Trucks
I have a 96 Dodge Ram 1500. Cranks and runs fine but after it warms up it dies. After cooling off its as if nothing is wrong til it warms up again then dies and wont crank. Talked with one person that said...
I don't know what testing you have done? When it stalls if it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs, if spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse. If your missing all three, I usually check the cam and crank sensors. There could be other issues? Any applicable trouble codes?
Jun 27, 2017 | Dodge Ram 1500 Cars & Trucks
Hello, HELP!! 2001 Escort ZX2. It wont starts. Spark at spark wires is OK. Fuel is there and you can smel fuel when I start the car. Looking down at the oil fill hole, the cam shaft rotae when starter is...
If I had 1 part to buy to try to fix this it would be a TPS. Throttle Position Sensor. This part should be on the side of the metal Airhorn which is after the Air filter ductwork. It has 2 bolts holding it on and 1 electric connector. The only tricky part to changing one is to line up the slot and groove it rides in before you tighten it.
The TPS matches the spark and the fuel to the gas pedal pressure and it acts like a Carburetor.
Nov 19, 2010 | 2001 Ford Escort ZX2
97 Pontiac Firebird V6 Not Starting
The fact that it starts occassionally suggest that the problem is an unreliable spark or a fuel issue.
Here's a list of things that might solve your problem;
Check the battery, if it's weak your engine won't roll fast enough and your spark will be weak. Take it to the auto parts store and have it checked, most stores will do it for free.
If you're using old gas that could be the whole problem.
Check all the ignition wires, a loose connection or bad wire is all it would take.
Check all the ignition parts, worn or dirty parts can cause your spark to miss or fire at the wrong time or place.
Check the spark plugs and wires, fouled or mis-gapped plugs or bad wires can cause misfires and oily wires can cause your spark to go almost anywhere.
Check the choke, if it's not operating correctly it can throw your air/fuel mixture way off.
I know this is a lot of stuff to check, I tried to be thorough but I know I left out the most expensive fixes, Stator, Coil, Distributor, ect...
I hope this helps, if so, I'd be curious to know what the problem was.
Jun 08, 2010 | 1997 Pontiac Firebird
Getting fuel, but it will not ignite. Its a 55,000 BTu Reddy Heater. Can I get some help please? Also, where can I buy the parts to fix? Thanks
Can you see a spark from the piezo starter? Also you have to hold the start valve until the temp gets up. Also make sure that the spark is jumping across the gas orifice. You can get parts at www.reddyheater.com They also have tips on how to troubleshoot you're unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 18, 2010 | Reddy Heater-30-55,000 BTU Variable
91 sonoma 4 cyl has no spark
Ok..after starting with fuses then cap and rotor..it turns out the 5 month old rotor was fried!! so problemo fixed.. thanks for suggestions. and to my mechanic friend who told me to start from scratch!
Feb 16, 2009 | 1995 GMC Sonoma
NO SPARK!
The crank and or the cam sensor has failed. If you have no way of pulling codes or checking for signals from the sensors, start with the crank sensor, its more common.
Feb 08, 2009 | 1997 Chrysler LHS
No spark at all after overall - buick 1991 lesabre
It sounds like you are saying that you replaced or rebuilt the engine. If you did make sure that all the connectors are plugged in. The crankshaft position sensor will cause the engine to not have spark. Let me know if you can think of anything else that may help me help you.
Dec 25, 2008 | 1991 Buick LeSabre
Popping, sparking, snapping
power house is fried these at times tend to go out but this time it might have had a little help animal or bug crossing or chewing on wires
i know alone on cost for the bulbs is around 300 to 400 dollars gotta estemate right around these odds for the power house price is around 200 parts and labor high voltage conductors
May 10, 2008 | Philips 51PP9200D Television
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
