Question about KitchenAid Dishwashers
I have a Kitchenaid dishwasher model YKUDS230B. The Cycle Complete light will not go off. I am unable to start the dishwasher with this light on. Karen
  • 9 Answers
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Posted on Aug 31, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher will not drain
Hello Tom_Simmers,
Here is a link with exploded views and parts lists for your dishwasher for reference however based on your description, have you made sure you don't a blockage in the check valve? That's part of the pump drain assembly. http://www.pcappliancerepair.com/model-display.php
You may also have a problem with the pump itself so the documentation on the website will help you evaluate that.
In many instances, its just a blockage of food byproducts inline with the drain system so chances are thats what you will find.. Good Luck on that.
Regards,
Rick
Posted on Dec 02, 2008
  • 25 Answers
SOURCE: Kitchenaid dishwasher mdl: kud101t jbt0
try the reset button sequence.. described in that other post about the clean light blinking.. that will reset the whole machine..
tpug
Posted on Jan 24, 2009
  • 1015 Answers
SOURCE: my KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
Posted on Sep 26, 2009
  • 70 Answers
SOURCE: Even when dishes are rinsed thoroughly, little
1)rinse not happening properly.
problem in filter(solenoid).
2)check the boiler tank any blockage.
Posted on Jan 13, 2010
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Kitchenaid superba
Do the dishwasher still operate or not?
Feb 23, 2008 | KitchenAid 24 in. KUDU02FR Built-in...
KITCHENAID DW KUDS30FXSS - 18 months old, will not complete cycles. Runs for 15 mins and stops & lights go out. Cleaning tablet often left in dispensor.
See my problem and solution. Sounds like you, too, are having a problem with the main control board (computer chip that controls the dishwasher), which is apparently a common problem with this model dishwasher. The part can be found here, for $211 (tax + shipping), and they have a 30-day return policy in the event that it does not fix the problem. It's an easy DIY fix. Hopefully this helps!
Aug 15, 2012 | KitchenAid KUDS30FXSS Builtin Dishwasher
I repalced a controller board and the Normal LED flashes and will not complete its cycle but a Light cycle will work ok.
Pl check the part no or the software version of the board. Contact the mfr with the model no and if possible the board no.
Or refer to the new guide or ask for it mentioning the present board you just replaced.
May 29, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Residue is left behind after cycle is complete. Dishes looks dirt
if dirt is not being washed away it is most likely you have a clogged screen before the waste tube. Depending on the model. Dismantling the dishwasher takes place inside it and under it where the motor is located.
Mar 13, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Lights flashing on clean. Program does not take.
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 07, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Mar 31, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishwashers Logo
71 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
