Question about Dishwashers
Hose to upper Propeller is disconnecting - Dishwashers
  • 10,865 Answers
Hello. If it is disconnecting from the front, use some plumber's putty to hold it in place. This is a cheap, common item usually about $1.00 for a small tube, at any hardware store, home depot, lowes, etc. If there is a broken or missing part go to searspartsdirect.com
There you will enter the model number and see all of the parts diagrams. This shows you exactly how things go together etc. And you can order parts there also.
Joe
Thanks for choosing Fixya!
Posted on Jan 03, 2011
My 2001 Pontiac Grand am is overheating. Thermostat is good and is not losing coolant
Plugged radiator, bad water pump, collapsed hose? Start the car and feel the upper and lower hoses to see if they collapse on themselves or pinched if a wrong hose was used. Sometimes the propeller in the water pump rusts off or fails so there will be little circulation.
Feb 08, 2017 | Pontiac Grand Am Cars & Trucks
Thermostat on 2005 aviator location
Removal & Installation
Print
4.6L & 5.4L SOHC Engines
  1. Partially drain the engine cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose from the water outlet adapter.
  3. Remove the power steering reservoir upper mounting bracket.
  4. Remove the bolts and remove the water outlet adapter.
  5. Remove the water thermostat and the O-ring seal. Discard the O-ring seal.
  6. Installation is the reverse of the removal procedure. Tighten the water outlet adapter bolts to 18 ft. lbs. (25 Nm). Tighten the power steering reservoir upper mounting bracket as shown in the accompanying illustration.
    Fig. View of the power steering reservoir upper mounting bracket and tightening specifications
    Fig. Exploded view of the water outlet adapter and tightening specifications
5.4L & 6.8L Engines
  1. Partially drain the cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose.
  3. Remove the coolant outlet connection, as follows:
    1. Remove the bolts.
    2. Remove the coolant outlet connection.
  4. Remove the (A) coolant thermostat and the (B) O-ring seal.
  5. Discard the (B) O-ring seal.
    Fig. Remove the (A) coolant thermostat and the (B) O-ring seal
To install:
NOTE Thermostat must be installed as illustrated.
  1. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold.
    Fig. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold
  2. Install the coolant outlet connection, as follows:
    1. Position the coolant outlet connection on the upper intake manifold.
    2. Install the bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
  3. Connect the upper radiator hose.
  4. Fill the cooling system.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Partially drain the cooling system to a level below the thermostat.
  3. Disconnect the upper radiator hose.
  4. Remove the coolant outlet connection, as follows:
  5. Remove the (A) coolant thermostat and the (B) O-ring seal.
  6. Discard the (B) O-ring seal.
To install:
5.4L DOHC Engine
  2. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter.
    Fig. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter
  3. Remove the water hose connection and thermostat.
  4. Installation is the reverse of the removal procedure. Tighten the mounting bolt to 18 ft. lbs. (25 Nm).
    Fig. Exploded view of the thermostat-5.4L DOHC engine
Aug 13, 2012 | 2004 Lincoln Aviator
My dishwasher will not drain
It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 07, 2012 | Maytag 24 in. MDB5600A Jetclean II...
Installing radiator
REMOVAL
1. DRAIN ENGINE COOLANT
2. w/ CRUISE CONTROL SYSTEM:
REMOVE CRUISE CONTROL ACTUATOR COVER
3. DISCONNECT ECT SWITCH CONNECTOR FROM FAN SHROUD
4. DISCONNECT ELECTRIC COOLING FAN CONNECTORS
5. REMOVE RADIATOR HOSES
(a) Disconnect the upper hose from the radiator side.
(b) Disconnect the lower hose from the water inlet pipe.
6. DISCONNECT RADIATOR RESERVOIR HOSE
7. A/T:
DISCONNECT OIL COOLER HOSES
8. REMOVE RADIATOR AND ELECTRIC COOLING FANS
(a) Remove the 2 bolts and 2 upper supports.
(b) Lift out the radiator.
(c) Remove the 2 lower radiator supports.
9. REMOVE RADIATOR LOWER HOSE
10. A/T:
REMOVE A/T OIL COOLER HOSES
11. REMOVE ECT SWITCH WIRE
12. REMOVE ELECTRIC COOLING FANS Assembly is reverse order.
Jan 01, 2011 | 1996 Toyota Camry
Need instructions on how to replace the cooling
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Radiator upper crossmember
    • Fan motor electrical connector
  3. Drain cooling system below the level of the upper radiator hose.
  4. Remove or disconnect the following:
    • Upper radiator hose from radiator
    • Radiator fan fasteners and upper clip
    • Fan assembly by lifting upward to clear radiator
To Install:
  1. Install or connect the following:
    • Radiator fan assembly
    • Upper clip and fasteners
    • Upper radiator hose to radiator
  2. Fill cooling system.
Jul 17, 2010 | 2004 Dodge Intrepid
Heli will not climb above ground effect, battery tests ok, axles in balance no vibration, just will not climb
I also have this kind of problem with my apache. The upper propeller must spin faster thatn the lower propeller if not the heli would just spin on its tail although maximum power is achieved. The solution is to check the connection of the gears and the axle of the upper propeller which is located at the bottom of the helicopter. remove first the battery pack to see clearly the connection. try to turn the upper propeller a few turns and see if the axle, gear and the metal connector is sliding. A fixed my heli buy putting a permanent glue on the axle, connector to the gear and whalla. it does not slide. Most problems of this model is the gear of the upper propeller, often times loosened specially during crushes. This will a lot help you as your heli would have power on the upper propeller for lift off. Happy flying.
Gerry1abe.
Mar 07, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Water is not draining from my Bosch DW. SHX45P06UC/57. The drain is not clogged.
1 drain pump propeller clogged or hose clogged.disconnect hose under sink and drain then will tell.
Feb 25, 2010 | Dishwashers
Hi my apache bottom wings are good but top wings dont spin they just sit there they were fine the first flight untill i crash it
Please check the connection of the axle of the upper propeller. Turn the heli upside down and spin the upper propeller manually, try to see if the gear turns if not there is a loose connection. You will find 2 small screws near the gear, unscrew one of them and push the axle then back in place, tighten the loosened screws. Turn the upper proppeller manualy, a few turns will do ansd see if the gear turns simultaneously with the propeller. If it still does not turn, apply a permanent glue to the gear and the axle. This will sure have your heli on flight.
Gerry.
Dec 29, 2009 | Apache Colco Ah 64 Longbow R/C Helicopter
I have a 94 jeep wrangler front left axle seal bad. I took the left side apart and not sure how to get the seal back in. Do I need to open the inspection cover on the diff. and take the gears out?
Rear Axle Notes
  1. Raise and support vehicle.
  2. Remove rear wheels.
  3. Scribe alignment marks on propeller shaft and axle for proper assembly, then disconnect propeller shaft from axle.
  4. Disconnect the track bar from axle mounting bracket.
  5. Disconnect parking brake cable at equalizer.
  6. Disconnect shock absorbers at axle tubes.
  7. Disconnect hydraulic brake hose at rear axle Tee-fitting, then tape ends of hose and fitting to prevent contamination.
  8. Disconnect axle vent tube from axle.
  9. Remove U-bolts and tie plates.
  10. Loosen spring mounting bolts.
  11. If equipped, disconnect ABS wiring connections at axle.
  12. Support axle with suitable jack.
  13. Remove spring-to-shackle attaching bolts and lower spring to the floor.
  14. Remove axle assembly.
  15. Reverse procedure to install.
Front Axle Notes
  1. Raise and support vehicle at frame behind front springs.
  2. Remove front wheels.
  3. Scribe alignment marks on propeller shaft and axle yoke for proper assembly, then disconnect propeller shaft at axle yoke.
  4. Disconnect connecting rod at steering knuckles.
  5. Disconnect shock absorbers at axle housing.
  6. Remove stabilizer bar connecting links to spring tie plates attaching bolts, if equipped.
  7. Disconnect breather tube at axle housing.
  8. Disconnect stabilizer bar link bolts at spring clips.
  9. Remove disc brake calipers, rotors and brake shields.
  10. Remove U-bolts and tie plates.
  11. Support axle assembly with suitable jack to relieve spring tension.
  12. Loosen rear spring shackle to spring attaching bolts.
  13. Remove front spring shackle to spring attaching bolts and lower spring to floor.
  14. Remove axle from under vehicle.
Jul 21, 2009 | 1994 Jeep Wrangler
How to replace a radiator in a chrysler concorde 1998 3.2
drain radiator.. remove upper and lower radiator hoses ,,remove transmission lines..remove bolts from cover on top of radiator.. lift out radiator.
Dec 06, 2008 | 1998 Chrysler Concorde
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
Owen Barnes
