What kind of slot I need to insert this ncomputing card, is it a special slot ?
  • 442 Answers
Ncomputing device comes in 3 fashion
USB - which can connect externally to a USB port
Ethernet - which can connect to the network port
PCI - which connects to the PCI slot in your motherboard. (usually cream in color)
In case you need more clarification please specify the motherboard make and model number so that we can confirm if that motherboard has a PCI slot.
Thank you for contacting Fixya
Posted on Jan 03, 2011
Ncomputing driver is not instol
If the driver did not load up, power off main computer, remove and re-insert it after 30 seconds then power back on, if it still doesn't load up go to their website and look for your model type over there.
May 09, 2012 | NComputing X300 3 User Expansion Kit...
Can not gt my sd card into the slot do u need a spefic kind
Yes the type of card matters for the slot. If your pc/ laptop is newer and you have never used the slot, then more than likely the dummy plastic piece is still in it. This needs to be removed before you can insert any cards into it. Also, an SD card will only fit an SD slot, there are many other types of cards as well. If your card slot says that it will except SD, XD, miniSD, and so on.....then you can insert the SD card that you have.
Aug 27, 2011 | Computers & Internet
I need Vista drivers for Extenda x300
According to this web page:
http://www.ncomputing.com/node/1629
You can download the drivers for the Extenda x300 here:
http://www.ncomputing.com/download/x300.zip
Please let me know if this helps,
Kind regards,
Chris
Mar 12, 2011 | NComputing X300 3 User Expansion Kit...
Is NComputing X300 3 User Expansion Kit can install and use in Windows 7. NComputing X300 3 User Expansion Kit software supports or not?
NComputing software updates are only available to registered NComputing customers. To install the software you must have a valid NComputing software license and you must read and agree to the terms in the End User License Agreement and Terms of Use.
Here is the LINK.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | NComputing X300 3 User Expansion Kit...
550 NCOMPUTING PROBLEM
when i insert ncomputing cd in my computers drive and want to install ncomputing softwere the massege appearce that "NComputing vSpace not installed
Error report:
This software is hardware protected. Your hardware is not supported. Please contact NComputing Inc. or its partners to purchase supported hardware. plz solve my problem as soon as thank u
Jul 16, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
Graphics
This board has a built in Integrated Intel Extereme Graphic 2 supports up to 64MB of video memory.  IF you are trying to upgrade it, you need a special kind of card.  It has a AGR (Advanced Graphics Riser) slot, which will only support compatible AGP VGA cards. What I suggest is to go to MSI's Hardware compatiblity  http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=∏_no=190   go to the bottom of the page to download the chart.
Good Luck!
Mark
Dec 12, 2008 | MSI 865GVM3-V Motherboard
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Computers & Internet Logo
David Payne
David Payne
