Question about Dishwashers
All the programme cycle lights come when any programme is selected. I have opened and cleaned the filters, drain pump and non-return valve. I have switched power off at the mains. I have also depressed the off switch for 5 secs as recommended on the Miele website and then re-started the machine. Still get the same error. Any suggestions would be gratefully received.
  • 1 more comment
  • Shankar Mukherjee Jan 04, 2011
    Hi there
    Apologies for the lack of details in the posting.
    1. Make : Miele. Model Number 04 867 721. I was told by Miele the model is G673 Integrated. Not absolutely sure about this.
    2. It is about 8 years old.
    3. There are no error codes since there is no display. All the program cycle lights (1 through 5) blink continuously when any program is selected after switching it on.
    Thanks
  • Shankar Mukherjee Jan 05, 2011
    Hi there many thanks for the reply. I followed the instructions. I pressed 2 and 3 together and then Power On. The intake light came on and also program lights 1 and 5 started to flash. I pressed 5, then program lights 1 and 2 started to flash. I pressed 1 and all the flashing lights went out and program light 5 came on and stayed on (steady not flashing). I switched off power and switched on again. Same problem as before. Please advise.
    Thanks very much for your prompt help.
  • 4,323 Answers
Hi
Try and reset the dishwasher by following this sequence---
Turn the power off to the machine.
Press and hold button 2 and 3 together while turning the dishwasher on. The salt and intake/drain lamp will flash. Now, Press button 5, then Press button 1
Are any of the lights (1-5) lit up, If not then press 6 and then cancel the cycle. Restart and check the dishwasher if it's working fine, if not then repeat the above procedure. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 05, 2011
  • Daniel Scott
    Daniel Scott Jan 05, 2011
    The control board seems to be bad and should be replaced.
  • 1,531 Answers
You will need to replace the main control board or timer if equipped.
  • 10,515 Answers
Kindly provide few more details :-
1. Make and model of the unit?
2. How old the unit is?
3. What error code you have received? ( You never mention that ).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 04, 2011
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Our 2 year old Miele dishwasher (G1182/G2182) makes a strange popping/grinding glass noise when draining. We used 1 bottle of Finish Intensive care & clean with no improvement. Any suggestions?
there is a piece of debris in the drain pump. remove the triple filter from the bottom ( the one you are supposed to clean every week to keep debris out of the drain pump) under that filter and to the left hand side you will see the non return valve. squeeze the tab and pull the non return valve out. remove the broken glass or whatever is stuck in the drain pump impeller. replace the non return valve. replace the filter. if you need a picture go to mieleusa.com, and search for your owners manual. it has step by step tutorials on how to free an obstruction from your drain pump.
May 27, 2012 | Miele Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Have just bought a secondhand Miele G7859 dishwasher. When turning on to any programme, it shows F11 fault code and beeps. I'll happily work through any suggestions! Thanks in advance Andy
F11 - Drainage fault
This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Hope ths helps.
May 20, 2011 | Dishwashers
Miele dishwasher finishes the cycle with water in the bottom and the dishes not clean
In the bottom of the dishwasher you have a filter. under the filter is a non return valve. it is a one way valve that keeps the dirty drain water from draining back into the dishwasher. if it is dirty or broken, the dirty water that your machine drains out, is running right back in as soon as the drain pump shuts off. this will keep happening and your dishwasher will just spray the dirty water back on the dishes over and over again.
to get to it, you will need to get the water out of the machine. if you have a wet dry shop vac use that. if not, you can bail it out with a cup, and soak the rest up with a sponge. remove the lower spray arm by pulling it up. remove the filter by pulling the handle in the direction of the arrow. lift the filter out of the way. get the rest of the water out of the sump. on the left side of the sump, you will see a silver wire bail holding the non return valve in. flip the bail towards the center of the sump. pull up and out on the non return valve. it has a rubber seal and a stainless steel ball inside. any debris between the seal and the ball will keep the valve from closing all the way, and allow the water to drain back. you can order a replacement if needed, directly from miele. 1800 842 7231.
Nov 19, 2010 | Miele G880 Dishwasher
Miele incognito not draining
at the bottom left corner their is a manual draining system maybe you need to use that with a bucket.
thats all i can think of unless it still has warranty just trade it in.
Oct 03, 2008 | Miele Novotronic Premier 500 Front Load...
Inlet/drain light remains on
I have the same problem on a Miele G647 SC Plus. It starts and completes the wash cycle, might skip a final rinse - not sure, but it drains the water. Pump then continues to run for extended period then inlet/outlet light comes on. The dishwasher never moves to the drying cycle.
I cleaned all filters, checked supply/drain hoses + the non return valve. All seemed servicable. But no real improvement in fault.
Any way I can fix this?
Jul 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Intake/Drain Error
There is water collected in the inner tray of your unit. Pull out the Miele and take off the drain hose and unplug the unit. Then tilt the dishwasher back 60* and let it drain out all the water. There will be a couple of cups on the floor, but nothing too big that a couple of towles can't handle. Then reconnect everything and start up the unit. It WILL work! It just happened to me and my Miele incognito is now working like a champ again!!
May 21, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
204 people viewed this question
Top Dishwashers Experts
