Question about Whirlpool Washing Machines
I have a whirlpool washing machine SM 8525492-A, purchased in 2007. It operates normally except for the spin cycle. Recently it will not spin during the spin cycle except for very small loads. With a medium or large load, it will not spin unless i remove most or all of the clothing, then it spins normally. All other functions, including draining, are operating normally.
SOURCE: My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Posted on Nov 14, 2008
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
SOURCE: Walking during the spin cycle
My GE front load washer model WCVH6800JBB have the same problem. I just purchased and installed it yesterday, 05/04/09. Just like everyone said... when it got to the spinning cycle it walked to the middle of my garage and all the connections in the back of the machine fell off. My husband checked the instruction... There are 4 nut bolts in the back of the machine near the rubber leg (level). You need to take them off and try to balance your machine again. My washer is running very smooth now. Good luck!
Posted on May 05, 2009
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
Whirlpool WTW4900BW1 Washing Machine Loud Banging on spin cycle.
Transporting a washing machine in any position except upright can be fatal. The reason? The original packing material is no longer in place.
May 16, 2017 | Whirlpool Washing Machines
How do I remove the lid from a top-load wash machine in order to repair the lid switch?
Most have snaps holding the top down. Just, carefully, pry upward at the front of the lid edge.
May 02, 2015 | Whirlpool Washing Machines
Whirlpool sm 8525492-b
sounds to me that the timer behind the dial is working improperly this is a cam operated timer and sounds like its malfunctioning. I cant look up the parts list off any site with the numbers u gave. but if I had to guess that cam timer is broke but a little troubleshooting would verify. remember if you decide to take a look inside the back panel yourself there are arc flash potential and electrocution. read manufacturer warnings and you may get lucky and remove the panel and find a schematic and troubleshooting guide. good luck.
Oct 21, 2013 | Washing Machines
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool SM 8525492-A will not spin. Please Help!
I just ran into the same problem.....did you get a fix yet?
Dec 16, 2010 | Washing Machines
Trying to locate the belt on a Whirlpool washer
Hi:
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
Feb 15, 2010 | Whirlpool Washing Machines
Whirlpool Duet Front Load
If you are using the recommended HE (High Efficiency) soap, you will not see alot of sudsing, this is normal. The washing action is very different than the top load machines. Excessive sudsing will cause issues with this machines operation.
Regards;
reg501
The FixYa Team
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
620 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
