Question about Dometic Rooftop RV Air Conditioner
Penguin AC cycling
Hi all,
I have strange problem that I can't get to the bottom of. I have 2 Duo-Therm Penguin 630515 installed and operated by a Comfort Control Center. The problem is with one of the units cycling when it is operating. No matter how low I set the temp, it will come on for exactly 10 min and then shut off for 2:30. This will go on all day and is exact to the second.
So far I have bypassed the EMS(Energy Management System) that sheds loads when amp draw exceeds input. I have verified that the therm is not sending the shutdown command and even switched "zones" on the CCC. I have switched the digital control boards between the rooftop units. I have checked the run cap, the start cap, the compressor and the PTCR valve per the spec/techniques in the Dometic troubleshooting guide. I have checked for air flow and obstruction in the duct and external fins.
What is perplexing is the exactness of the problem. If it were something freezing up or overheating I would expect the cycle times to be variable. The exactness of the cycle times points to a digital control problem but I can't seem to locate it.
The other unit runs fine, so if I set it very low in temp it will run constantly.
Any ideas on where to look next?
Thanks
Todd
  • Dometic Master
  • 6,674 Answers
Did you try contacting Dometic directly, to speak to a technical assistant. ( www.dometicusa.com )
Posted on Aug 16, 2008
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
Duo Therm Model 630515
check freeze sensor should be plugged into coil then air box cannot mix intake and cold air if all ok low on Freon cannot refill
Oct 04, 2008 | Dometic Rooftop RV Air Conditioner
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
460 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
