Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Hp1212nf wont come out of initialization mode. How to fix
  • 152 Answers
Hello, this sounds like a main formatter board malfunction.
Hewlett Packard may be able to provide warranty repair for this model.
For more information, follow link below.
M1522INFORMATION
Posted on Feb 04, 2011
Navara d40 has no power wont rev more than 3000 rev thanks
Sounds like your vehicle is in limp mode. Check for faults with a fault code scanner at a local auto parts store. Resetting the fault will fix the limp mode, but not whatever caused your vehicle to initiate limp mode.
Sep 12, 2013 | Cars & Trucks
My panasonic vieta th-50pz85u. wont power on. it flashes 9 times. then it will consistantly flash six times. how can i fix this
This is on a protection mode. Since the back cover has to be opened for investigation, it is better to call in a qualified service technician.
Aug 17, 2012 | Televison & Video
CD player wont play and says "initializing"
This is common problem with CD players. Try to clean the Lens first by using CD cleaner. If same issue will happen after cleaning. You need to bring the unit to an electrician and have it opened and have the Lens adjusted.
Jun 07, 2010 | 2003 Hummer H2
The flash wont work on the camera...still
1. Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies. * When shooting in the Twilight or Handheld Twilight mode. * If shooting with the Burst or Multi Burst mode. * Shooting with Sweep Panorama. * Shooting with the Fireworks or High Sensitivity mode. * If an external flash is connected.
2. You can also Initialize the Camera. Touch the Home option. Then, select the Main Settings and then, select the Main Setting2 option. Then, select the Initialize option to OK.
3. You can also try to select the Flash Forced option to ON. The Flash Forced option is located under the Flash Settings.
Jan 10, 2010 | Sony DSC-T70 Digital Camera
Wont boot
Failed to initiate error means that either the hard drive or hard drive controller have failed. Your best bet is replace the hard drive. If the data is valuable there are some companies which can recover for a price.
Dec 15, 2009 | ASUS Eee 4G Notebook
1997 Nissan Terrano electronic compass blinking
CORRECTION FUNCTIONS OF COMPASS
NAEL0307S01
The direction display is equipped with automatic correction function.
If the direction is not shown correctly, carry out initial correction.
INITIAL CORRECTION PROCEDURE FOR COMPASS
NAEL0307S02
1. Pushing the “Mode” switch for about 10 seconds will enter the
initial correction mode. The direction bar starts blinking.
2. Turn the vehicle slowly in an open, safe place. The initial correction
is completed in one or two turns.
NOTE:
In places where the terrestrial magnetism is extremely disturbed,
the initial correction may start automatically
Feb 08, 2009 | 1997 Nissan Pathfinder
Can't get out of safe mode
While booting ur system press F8 initially when system turned on you will get booting options .Select Normal and Enter you can able to boot in normal mode.
Oct 26, 2008 | Microsoft Windows 2000 Professional for PC
Machine Error 71, Brother MFC 8440
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Sep 26, 2008 | Office Equipment & Supplies
System initializing
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 19, 2008 | iRiver H10 MP3 Player
Black wont print
sure. if you re lucky the generic ink hasn t destroyed the ph bk channel yet:
use skyhorse carts (http://www.skyhorse.net.cn ) who built good and reliable carts with a very good ink quality!
To get bk again:
press menu tehn start bk copy then fourtimes arrow up. machines will
be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will initialize the carts, refresh all tubes and ph channels with fesh ink and eliminates the air bubbles (quite a big prob within brother inkjet printers). When finished press 7 -6 -3 to
run a power purge. leave the maintenance mode by pressing 9 then 9. do run a test print.
If you cant see ANY bk the ph is clogged and cant be fixed any more. it needs replacing then.
Apr 05, 2008 | Brother Multi-Function Center MFC-240C...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
636 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
