Question about Vizio M420VT 42 in. LCD HDTV
Screen darkens randomly as if ambient light sensor were kicking in. I have the ambient light sensor turned off!
The Ambient Light Sensor isn't perfect, but if you're having the same problem I had, it's not an issue with the Ambient Light Sensor. Rather, your solution will be turning DCR (Dynamic Contrast Ratio) to Off.
Go to the PICTURE menu and choose Picture Mode. You can turn off DCR in one of two ways: Choose "Custom" and set it manually, or choose "Movie" or "Game" for your picture mode. (The "Movie" and "Game" default settings include DCR=off, whereas "Home" will include DCR=on.)
Keep in mind that you will need to make these changes for each input (HDMI, Comp, AV, DTV/TV). Also, if you continue to have trouble you can also try playing with Adaptive Luma under the "Custom" settings.
Posted on Jan 24, 2011
Television screen turns dark
A lot of these smart televisions have an autoset configuration where you can go in and set it to auto dim when the outside ambient light changes. It can also be put on a timer. Saying it is at random may be because of both of these features being active at the same time. I would go into the settings and check these settings.
Lastly, the signal you are receiving can change which can cause the auto dim to kick in.
If this does not resolve you issue, you may have a back light going out and I would recommend taking it to a reputable repair shop for evaluation.
Hope this helps.
Apr 25, 2017 | Samsung Televison & Video
My htc has a dark screen and still works and by dark i mean you can barley see any thing but sometimes the screen goes back to normal light
Is your phone a smart phone?? Does it have something called ambient light sensor (light sensor).??? Check your phone manual. If that is the case then you can turn it off. Ambient light sensor is a function that senses the light outside and automatically adjust the brightness of the screen. But sometimes it goofes up. So you can go to settings> display settings> brightness> if it is auto then turn it to manual as per your convenience. Again depending on your phone model the settings may vary. I hope this helps.
Jan 17, 2014 | HTC explorer
My new UN55ES6150 dims after a few seconds of being turned on. Is it adjusting to ambient conditions or is there something wrong with it? (It also seems to dim and adjust back randomly after the initial...
this is a feature called eco sensor. it will dim the backlight in response to light level in the room. go to advanced picture controls in the same menu and turn eco sensor off. meder's tv service...good success and God bless.
Sep 11, 2013 | Samsung UN55ES6150F
Tv screen darkens at night
The set likely has a light sensor on the front of it to change brightness with light changes in the room, if not in the menu to switch on or off contact LG to see with the model number what can be done.
I have seen some where the sensor had to be disconnected inside to correct this issue. Sets as far back as 50 years ago had this issue.
Oct 22, 2012 | LG Televison & Video
What do I do if half my iTouch screen is to bright
Hi, I hope I can be helpful, on your home screen , select the icon for settingds, looks like a small wheel, this will open your next screen where you wiil find the sith option as you go down it's called brightness, select and you'll enter the screen where you can manually slide the line back and forth until it's comfortable for you, or you have the the option of checking the box called"autoadjust" it will either brighten or darken automatically dending on the ambient lighting through it's sensor.
hope I was of help.
MJ
Jun 18, 2012 | Apple Nice Ipod Touch Itouch 4th Gen 8gb...
My screen is darkening
Check in the menu that you have not selected the option which changes the screen brightness according to the ambient light.
I hope I have been of help and please do hesitate to ask if you have any further questions.
Feb 21, 2011 | GPS
Lamp is sitting next to my computer. When lamp is turned on, it darkens computer screen. Computer screen light returns when lamp is turned off.
Your computer screen may have a light leveling sensor, if you find your monitor has this you can cover the sensor with electrical or masking tape. Clear plastic tape will not help. Good Luck!
Douglas
Jan 02, 2011 | Verilux Modern Deluxe Natural Spectrum...
After 5 minutes monitor screen dims--can faintly see the windows screen and then it flickers out and there is nothing. Any ideas?
the monitor may be going into power save mode which it should come out of when you press a key or move the mouse but it sounds like you have tube inverter issues. Your screen has light tubes behind it to illuminate the screen, if the tubes or the inverter develop a fault, then a very dark screen can result as the tubes are turned off. There may also be an ambient light sensor which will darken the screen in low ambient light. If the sensor is faulty, darkened screens will result. If the inverter is failing, you may be able to replace it, contact viewsonic. if the tubes are failing, replace the panel or the entire monitor. If the ambient light sensor is faulty, replace the panel or entire monitor as the sensor is part of the display panel.
Nov 02, 2009 | ViewSonic VG900b 19" LCD Monitor
Monitor darkens down every few minutes. It relights when i open and close lid.
Could be your power settings. Some new laptops adjust screen brightness due to ambient light.
May 25, 2009 | Computers & Internet
My acer aspire 9300 screen is so dim i can barely see anything
Hi.
      Have you tried adjusting the Brightness of the Display? May seem like a stupid thing to ask, but some laptops come with what is known as Ambient Light Sensors and by setting a higher brightness level it Disables the Ambient Light Sensor kicking in.
Dec 03, 2008 | Acer Aspire 9300 Notebook
Vizio M420VT 42 in. LCD HDTV Logo
622 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
