Question about Asko W6461 Front Load Washer
My Asko front loader is saying "fault indicator foaming".while in mid-cycle. What do I do?
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
hattonhall
  • 349 Answers
SOURCE: asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Posted on Oct 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Asko 20605 washer stopped mid-cycle, now no power?!
The ECU should be tested. Look for the service manual inside the chassis for troubleshooting procedures.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
taran_2005
  • 10515 Answers
SOURCE: Asko Front loader washing Machine
This is not a good news. This is an indication of an internal failure. If the pump has blocked and the thermal overload has gone open circuit, just remove the blockage from the pump, the module and the pump should still be okay.
If the pump windings are water damaged, the pump will quickly overheat and cut off again. The pump must be replaced in this case. The electronics should still be okay.
However, on most cases, this error message indicates Faulty pump or a faulty pump and board.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 28, 2010
rickyrt441
  • 4399 Answers
SOURCE: Hi, my Asko W6011 Quattro
Thanks for choosing FixYa and welcome.
Posted on Jun 06, 2011
Fault 02
Hi
Fault code 2 indicates "Water level too high "
Please look for the following causes:
· Plugged/Bad water pump
· Faulty water valve
If you are not able to check these, it may be necessary to call for a technician. Always be careful of electricity!
Jan 02, 2008 | Asko W6021 Front Load Washer
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Asko washer 20004 stopped mid cycle, water is
Oct 19, 2009 | Washing Machines
Mar 10, 2009 | Asko W640
Asko W640 - sporadically says motor fault and won't run, or, won't stop running, gets stuck on the spin cycle. We've had the motor fault problem before, but this "running on" issue is...
I would say the won't-run problem is separate from the run-on problem. You can live with the run-on problem -- probably a fault in the controller. Unless it's a faulty code, the motor-fault light probably means the motor is overheating. That can be caused by anything that causes it to work hard, such as a stuck pump.
Nov 26, 2008 | Asko Washing Machines
Machine stops mid cycle saying "faulty water outlet".
check filter, check for foreign object jamming pump impellor and check drain hose is not kinked or blocked
Aug 28, 2008 | Asko Washing Machines
The water temperature fault indicator is on
I think te problem may be the Termistor(temperature sensor) that is faulty. You need a technician from Asko to replace it.
Dec 13, 2007 | Asko W6661 Front Load Washer
Washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Asko W6461 Front Load Washer Logo
64 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
