Question about Watches
I need the user manual for New Balance N4 HR Monitor
WATCH ON DESKFOR 24 HOURS KEEPS PERFECT TIME'WHEN I WEAR WATCH IT LOSES IN 1 HR. LOSES 40 MIN. BATTERY NEW. OMEGA CONSTELLATION 30 YEARS OLD CAN YOU HELP?
When a watch is on a desk, the balance wheel is vertical, when you are wearing it the balance wheel horizontal.
Has the watch been dropped onto a hard surface?
If the balance wheel bearing is worn or has suffered a large shock, then the shaft may move in its bearings or the bearings damaged, which may give the problem you decscribe.
Take it to a watch repairer to have it adjusted or repaired.
Dec 27, 2010 | Omega Watches
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
How do I set the High hr and the low hr by the chart?
To change any of the settings, press 'set' until 'settings' is displayed, press 'ok', now you can either set the heart rate manually in 'limit set' (press 'ok' to change the settings and press 'set' to change)
or input your personal data to let it choose heart rate settings itself in 'user set' where you input weight, height, age and *** (sadly yes please is not one of the options ;¬) )
if you go to www.polar.fi the user manual is on there if you need more clarification.
Hope that helps,
Andy
Sep 18, 2009 | Polar F4 Heart Rate Monitor Watch
Polar F4 monitor is reading about 30bpm less than actual
Check that the case back is on the right way. A spring sticking out of the watch mech needs to line up with a hole in the white sticker on the inside of the case back, I think this is the receiver aerial.
Jul 20, 2009 | Polar F4 Heart Rate Monitor Watch
How do I switch from 24hr mode to 12 hr mode?
Check out the manufacturers web site, some manufactureres have users manuals for their watches which can be downloaded. You may be lucky. You could also try some of the various manuals websites. They have manuals for all manor of things. Good Luck
Jul 19, 2009 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Heart Rate monitor not working
Follow this link and download complete manual;
http://www.polar.fi/en/support/product_support?product=275&category=Downloads
Rate me, please.
Mar 24, 2009 | Polar F4 Heart Rate Monitor Watch
Change time to 24 hr from 12
Go to:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Full user manual and instructions there to download.
Feb 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
495 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
