I have a pretty old Dell computer. Recently the colors change and then return to normal. It is mostly a yellowing of the screen.
  • 84 Answers
That really happens if you've been using the monitor for a couple of years already. There no fix for that but to replace the monitor, I would recommend getting an LCD or LED monitor, those are energy efficient.
Posted on Jan 03, 2011
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
I have been using the Dell E196FP screen without problems for three cnsequitive years, recently however, the screen can only be swicted off when the PC is still on, when the pC is switched off the screen...
Dutch Dell helpdesk is not quite client focussed, but their sales department normally easily finds the right technician for you
Or in Dutch:
De Dell helpdesk in Nederland is niet bepaald klantgericht. Het beste kun je de verkoopafdeling bellen en uitleggen wat er aan de hand is en dat de helpdesk je niet fatsoenlijk helpt. De verkoopafdeling kan je waarschijnlijk snel in contact brengen met de juiste persoon.
May 06, 2009 | Dell E196FP 19" LCD Monitor
My monitor (Dell, 17", flat screen, about 2 years old)has recently started changing colors spontaneously. This happens whether the computer is on or not. It cycles through a bright yellow screen to bight...
they can do this if the monitor is shorting its self, might just need a dust out with a paint brush, while you have the back of the monitor check the main-av-power board and look for signs of weak capacitors this can also cause the same faults.
May 19, 2017 | Dell E176FP 17" LCD Monitor
The screen won´t work, please help.
Looks like your screen going to 'kaput' already.....anyway try to reseat the memory modules 1st. If u had the luck..it may works that way.....good luck
Sep 14, 2008 | Dell Latitude D600 Notebook
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
